It is likely that your seeing that software in the stream because it's in the process of sent out nationally, across the country.
who validates that site is 110% on-time and accurate at each moment?
Great, except almost nobody knows when such and such software is IN the datastream.
If you don't have any idea what the particular software is going to do, are you going to just up and download it ?
If you read the follow up post where I gave the site, you'll see that you most certainly can know at any given moment exactly WHAT software is in the stream for any given receiver. As for knowing what a particular software does, it isn't that hard to figure out... It's not like they are going to throw out software on the stream for a given receiver that's going to break said receiver.
Sure you're doing it at your own risk obviously... But most people doing such things are well versed in the risks.
With the Firmware Watcher...
So for example, looking in the HR section you can see that for the HR24-500 the 0x576 software was on the stream from about 2:51am (pacific) till about 3:56am (pacific) this morning...
So, if I'm reading that page right, you can't tell what is coming up, only whats streaming at the current time and previous.
It should be in HD if you are watching it from the Whole Home network.
looks like 057B is rolling out to many now, they are finally speeding up the HD UI rollout.
what made it speed up after 3months?looks like 057B is rolling out to many now, they are finally speeding up the HD UI rollout.
Limited time offer
