How long does it take to solve this error 789 issue? Its been almost two months since it started. This is so annoying.
I have L721 software. Every time I check the connection it says broadband is connected. However, when I do analysis and send data it shows no connection. I go through all the steps and finally get a connection with a confirmation code. This lasts until I shut the unit down and then it recyles to not connected. In addition , I have been trying to find 3D movies o nvideo on demand. I was told the 722 is 3D capable. However, I have never been able to find a 3D movie on VOD channels 1 or 501. Is this the same broadband connection problem?
I wish Dish would post some short 5 minute or so 1080p and 3D demos to stream so folks could see that it really works for them.
The connection issue sounds like it may be the same. The box loses its mind and thinks it is not connected, even though it still is (you can still ping the box and even sling will usually work).
The no-3D is separate. 722 does support 3D now and it does work. However, I do not believe they have any 3D on the streaming service at this time. The only 3D I have seen so far was Captain America on 1/501 for two or three weeks, but that has dropped off now.
same hereRecently received L7.22 on my 722 and the connection issue still exists....
Dish says they hope to get it fixed in the first quarter of 2012.
Limited time offer
