How to do the IAMANEDGECUTTER? | SatelliteGuys.US
Chris36
448
4
Rhode Island
Don't know if I'm doing something wrong. How do you do this? I do the smart search type source code then hit red button correct? Then it keeps up with 14 options all,movies, sports, 3D etc in Category and nothing in Subcategory. I must be missing something in the steps.
Thank you,
Chris
Do a smart search using IAMANEDGECUTTER. Then hit enter. It may take a few hours to take effect. That's it!
What exactly is this code/feature for and do when you put it in the smart search?
Yes, you put it in the Smart Search.
Currently, it's allowing the software downloaded last night to activate Pandora and YouTube.
Normally it activates a screen so you can report trouble.
Thank you for the help I'm away from home now I will try it this week. I did figure out how to do the 30 sex skip I got that working today. Makes it easier then stopping every 30 seconds. Like Dish has.
Merry Christmas everyone!!
Chris
Chris
Hmmm, a Freudian slip? ;)
Brand new DirectTV cust. From Dish
SWM and adding second receiver
