CE's for the Weekend of 2.10 | Page 8 | SatelliteGuys.US
Does anyone have any idea why there was no content released for the HR34 this weekend. Not previously being familiar with the whole CE process, I inadvertently got the CE release of the HD GUI from the weekend of 2/3. Later, out of ignorance, I forced another software update outside of the CE release window and it reverted my receiver back to the SD GUI (0x4C9).
Any idea when the next opportunity to download the HD GUI for the HR34 will be?
Welcome to the Site !
Its been pretty steady, probably this coming weekend, that said, you'll wat to check te CE. Forum closer to the w/e, Jason or Don usually post the notes when they get them, typically 10 ish, sometimes sooner, sometimes later, just depends on when they get sent to them.
Sent from my Samsung Epic using SatelliteGuys
I went back to NR. Last week's beta caused both of my HR24's fits. Couldn't change channels unless it was from the guide, upstairs 24 kept disconnecting from MRV, and DVR'd shows started from the beginning if stopped. Yes, I did numerous RBRs. I'll tyr again next weekend.
S~
5b3 has been the fastest so far on my HR24-500 and within a second I can access now my recordings. Previous ones took sometime up to 10secs with HD gui.
Sent from my SPH-D710 using Tapatalk
There are tons of MRV issues with this HR CE.
All I seem to do since Sat. is Reset this one or that one. And my HR34 a few time a day to get current MRV PlayList from the other DVRs on this HR CE.
This just shows that the issues are not consistantly on all makes and models as well as consistantly on 1 model all together.
If you go back to NR on a DVR, are the recordings and series links staying intact?
Got the weird red guide just now. Anyone else get it on this CE? Hr24-200.
- via iPhone 4S
I got it the other day on my HR24-100 so I sent in a report and reverted to the NR...
I also had to revert to NR this week as the red guide issue was driving me absolutely crazy. Just wanted to ask if it was normal for the Misc. Options menu to stay when you revert back to national? I still have it in my Settings. Wasn't sure if there was a way to turn it off or not.
Dan
HR2x / H21-H25 CE Release 2/10
HR34 MRV issues
