Empty DVR Recording Won't Delete | SatelliteGuys.US
DustoMan
1,247
19
Sparta, Wisconsin, United States
Did a box exchange about two weeks ago and I was a little surprised when the thing finally installed the most current software that there was some recordings showing up under the My Recordings area. I would have thought that when units were refurbished that the hard drives would have been scrubbed, but I guess not. Anyway, my problem is that after deleting everything and then importing programing back onto the DVR's drive, I have this empty box with a program named "House" and just some generic guide information. I can't play it and I can't delete it. I want to get rid of it cause it's kinda annoying. DIRT, is there anything I can do?
This is the first time I've heard of something being stuck on the hard drive. Have you tried hard resetting, then attempting to delete? Factory defaults would be a good idea if it still won't go away
Has anyone found a solution for this? I have the same issue and it is now interfering with recording shows. Have tried a hard reset and restoring factory settings. The video still won't delete.
Can you move it out of the way onto an EHD? If so, move it there and use Linux to delete it.
I've gone into edit and check the empty file to delete. Doing it from the main index of what's on the dvr with delete fails in that case but edit has gotten it.
When I try that, it doesn't delete the empty recording (even though it is checked), but does delete the "full" recording of whatever show is next to it. If there are no recordings, the empty recording goes away, but as soon as I record something, it comes back empty. Deleted all timers and rebuilt them and the empty recording still returns when I record any show.
722 Dual Mode recording - is this normal behavior?
2 set ups 1 receiver
