Matt....you are the man. They are indeed coming in. Thank you so much. Thank you, thank you, thank you!!!!!!
Nice job Matt. Just curious. Did you tag him with a western arc dish? I have a dish mover tomorrow that's gotta be EA and I'd like it to go smoothly of course.
Perfect. I'll do the same. Thanks!
A "tag" in our system tells us what satellites you're pointed at, and determines what channels you can receive (which is typically all because most people are on a full arc setup).
Example: If you want to have International channels added to your account, but 118.7 isn't "tagged" on your account, but you do have 118.7 installed, our system won't let us add the programming without sending someone to install 118.7.
We would have you check your orbitals, and if we find you had 118.7 installed already, we fix the tags, and would be able to add the programming without sending a tech.
95% of our customers are tagged properly, and it is most likely determined by what Arc your DMA is.
Limited time offer
