5/3/2012 1:18am - Uplink Activity Report - 35 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 5/3/2012 1:18am - 35 changes
Uplink Comparison Range: 05/02/2012 06:01P - 05/03/2012 01:17A
Channel Additions:
4630 - RFDTV [MPEG2 SD] added to EchoStar11 110W TP 21 ConUS beam (RFD TV) (A) (H)
4630 - RFDTV [MPEG4 SD] added to Nimiq5 72.7W TP 05 ConUS beam (RFD TV) (A) (H)
4631 - RFDTV [MPEG4 HD] added to Ciel-2 129W TP 19 ConUS beam (RFD TV) (A) (H)
4631 - RFDTV [MPEG4 HD] added to Nimiq5 72.7W TP 16 ConUS beam (RFD TV) (A) (H)
Channel Removals:
4580 - RFDTV (A) (H) [MPEG2 SD] removed from EchoStar11 110W TP 21 ConUS beam (RFD TV)
4580 - RFDTV (A) (H) [MPEG4 SD] removed from Nimiq5 72.7W TP 05 ConUS beam (RFD TV)
4581 - RFDTV (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 19 ConUS beam (RFD TV)
4581 - RFDTV (A) (H) [MPEG4 HD] removed from Nimiq5 72.7W TP 16 ConUS beam (RFD TV)
Channel Moves:
5190 - WQAD [MPEG4 HD] moved from EchoStar8 77W TP 06 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Davenport, IA-Moline, IL-ABC) (A) (H)
5191 - WHBF [MPEG4 HD] moved from EchoStar8 77W TP 06 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Davenport, IA-Rock Island, IL-CBS) (A) (H)
5192 - KWQC [MPEG4 HD] moved from EchoStar8 77W TP 06 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Davenport, IA-Davenport, IA-NBC) (A) (H)
5193 - KLJB [MPEG4 HD] moved from EchoStar8 77W TP 06 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Davenport, IA-Davenport, IA-FOX) (A) (H)
5194 - KQIN [MPEG4 HD] moved from EchoStar8 77W TP 06 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Davenport, IA-Davenport, IA-PBS) (A) (H)
5195 - WQPT [MPEG4 HD] moved from EchoStar8 77W TP 06 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Davenport, IA-Moline, IL-PBS) (A) (H)
7604 - KGCW [MPEG4 SD] moved from EchoStar8 77W TP 06 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Davenport, IA-Burlington, IA-CW) (A) (H)
5270 - WEHT [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Evansville, IN-Evansville, IN-ABC) (A) (H)
5271 - WEVV [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Evansville, IN-Evansville, IN-CBS) (A) (H)
5272 - WFIE [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Evansville, IN-Evansville, IN-NBC) (A) (H)
5274 - WNIN [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Evansville, IN-Evansville, IN-PBS) (A) (H)
5275 - WKOH [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Evansville, IN-Owensboro, KY-PBS) (A) (H)
5276 - WEVVD [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Evansville, IN-Evansville, IN-N/A) (A) (H)
7369 - WAZE [MPEG4 SD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Evansville, IN-Evansville, IN-CW) (A) (H)
5255 - WCMV [MPEG4 HD] moved from EchoStar15 61.5W TP 32 ConUS beam to EchoStar15 61.5W TP 04 ConUS beam (Mkt:Traverse City, MI-Cadillac, MI-PBS) (A) (H)
1 - VOD1 [VOD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (Video on Demand - Instant Pay Per View Movies) (NA)
501 - VOD0 [VOD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (Video on Demand Service) (NA)
6800 - UP4 [MPEG4 HD] moved from EchoStar8 77W TP 08 ConUS beam to EchoStar8 77W TP 06 ConUS beam (Virtual Channel) (NA)
6847 - UP11 [MPEG4 HD] moved from EchoStar8 77W TP 20 ConUS beam to EchoStar8 77W TP 18 ConUS beam (Virtual Channel) (NA)
9620 - BTV [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (Business TV) (A)
19140 - TRIGC [DATA] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (A)
30201 - VMTRG [DATA] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (A)
31500 - KFUG [144] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (A)
31510 - DLSV [136] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (A)
32767 - WB200 [128] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (A) (H)
32768 - WBSTR [128] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (A)
Channel Renames:
15242 - KESQ2 (OTA EPG:Palm Springs, CA)- EchoStar10 110W TP 31 Spotbeam 39 renamed to KESQ4 (OTA EPG:Palm Springs, CA)(NA)
Channels in the system: 8541
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2012 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.04.10
© 2012 - All Rights Reserved - SatelliteGuys Incorporated
Did they do anything to the Rochester, NY locals? While watching WHEC channel 10, the signal went bad around 7:30 am. Lot's of pixilation, jumping picture, etc. Same thing happened last week when they did change the local transponders.
Rochester is on 61.5. Most of this uplink change is on 77.
The reason I asked was that I had the same thing happen when they did change the transponders a few days ago. Happened about the same time of day, 7:30 AM EDT.
D
5/1/2012 7:02pm - Uplink Activity Report - 2 changes
D
5/4/2012 5:02pm - Uplink Activity Report - 6 changes
