Yesterday I performed a test of several LNBFs on satellites:
97w - Peaked using TP frequency 11706
99w - Peaked using TP frequency 11707
103w - Peaked using TP frequency 11942
125w - Peaked using TP frequency 12140
The tests were performed on these LNBFS:
I was using a SuperBuddy DVBS to test, so was unable to test and document the 103w S2 (offset skew transponders). The tests were performed using a 3 second lock time frame to allow plenty of time to assure a lock if the signal was available. (need to upgrade to the new S2 ....
Satellites 103w and 125W provided some transponders that would not lock on some of the LNBFs and certainly made the PLL LNBFs performance stand out. The DMS and GEOSATpro PLLs are very close in performance and with the close testing results it could be attributed to batch variations. The model averages do not tell the real story as there are some transponders that were real barn burners on a specific LNBF, but overall the unit did not produce the desireable flat response across the entire band. These PDFs should provide some interesting study.
For the record, I will take a SL1PLL over any other LNBF tested.... Hands down the SL1PLL is the overall performer! Since that statement is coming from the distributor, take it for what it is worth and let's see the results of your tests. I am confident that we will hear similar reports.
- GEOSATpro SL1PLL
- DMS PLL321s
- WSI ESX521
- WSI ESX522
- Invacom SNH031
- Chaparral
