I'd assume the former. Stations were provided receivers.Now why is it you think that given all this time some stations have not upgraded to DVB-S2, is it just plain procrastination or money issues?
It's no more bit-starved than any other broadcast network. ATSC requires MPEG-2, so that's what PBS/ABC/NBC/FOX/CBS/CW use.
Using MPEG-2 has nothing to do with dumbing things down for noob viewers. It's required. "Halving" (720p actually has more pixels/second than 1080i) the resolution to 720p is actually not a bad idea if you can't allocate enough bits to do 1080i properly (for some definition of "properly").
PBS actually did tests showing that even when stations broadcast MPEG-2, switching distribution to MPEG-4 gave a measurable improvement. IIRC, those tests used MPEG-2 at ~13Mbit/s.
Remember that digital conversion thing that took >10 years? Where Congress had to push the deadline multiple times and subsidize tuners so that NTSC could end? You expect to repeat that process barely three years later and make OTA viewers buy another new TV? Just because ATSC added AVC in A/73 doesn't mean anyone supports it. A/53 also has a 16VSB mode that nobody uses. The FCC incorporated A/53 only (and not even the newest version).H.264 has been part of the ATSC standards since 2008. Broadcasters could use H.264 over ATSC if they wanted to, but they'd rather accommodate stubborn people who don't want to update their equipment to handle a codec that is not 16 years old, so we all must suffer with MPEG-2 because of people with MPEG-2 only equipment dragging us down.
Certainly no broadcaster is going willingly lose viewers by switching to AVC. The FCC mandate for DTV is to replicate NTSC service, so there would still have to be an SD MPEG-2 program in the mux anyway. Your dream of 18 Mbit/s AVC will never happen. Wait for ATSC 2.0 or 3.0.Again. It's not required. They could leave all the viewers with equipment that can only handle MPEG-2 in the dark if they wanted to. They would rather cater to the lowest common denominator, however.
1280 x 720 x 60000/1001 = 55240759 pixels/sec720p does not have more pixels/second than 1080i. You pulled that one out of thin air.
Given a fixed output bitrate, a better input will yield better output. It's irrelevant that the output is 11 Mbit/s (pathetic or not). CBR at that rate is crap, but maybe not if that's the long-term average within a statmux.Most PBS affiliates run at 11 Mbps. It's pathetic. That disturbingly low bitrate will introduce enough artifacts of its own that it diminishes any quality that may be gained by having a higher source material.
30fps stutters too much (especially on a CRT). Any respectable TV will bob 1080@30i to 1080@60p.
1080i broadcasts at 60 fields per second with each field consisting of 1,036,800 pixels. These fields are then de-interlaced on the fly by your equipment to 1080p video @ 30 frames per second with 2,073,600 pixels to a frame.
Xizer said:720p does not have more pixels/second than 1080i. You pulled that one out of thin air.
1920 x 540 x 60000/1001 = 62145854 pixels/sec
It's highly unlikely your TV has a better deinterlacer than your local station.
it looks like those feeds with the symbol rate of 4444 went DVB-S2. At least they were last night (the 12175 H 4444 was still DVB)
crazy thing.....the Micro didnt even need a rescan. It just changed over (and the signal is alot lower on those than when they were DVB)
everything is still up there as of today
vertical side
12106 V 2397** Montana
12114 V 8703** Oklahoma
12060 V 30000
12140 V 30000
12180 V 30000**
Horizontal
12150 H 14028
12163 H 4444**
12169 H 4444**
12175 H 4444
**-DVB-S2 transponders
I gave up trying to keep track of this until they finally turn whatever off for good. Then I'll scan the correct Tp's and be done with it lol...The banner running across the screen is annoying too.
Me too. I will miss them while they are gome. Wake me up when they come back.:
Limited time offer
