pics of the dish farm...post yours too :) | Page 26 | SatelliteGuys.US
Here are a few pictures of the warehouse dish farm. Relocated about 500' South on roof to an area over our new tech area.
Sami 7.5' / GEOSATpro C2 LNBF / 36" Von Wiess actuator / Custom NPRM (50w - 180w+)
GEOSATpro 90cm with GEOSATpro SL2 / NPRM fixed on G19
GEOSATpro 90cm / GEOSATpro SL2 / GEOSATpro HH90 motor / NPRM (55w - 180w+) wish there was KU out west!
Terrestrial VHF/UHF on rotor / NPRM (65+ stations from Chico to San Jose)
GEOSATpro 1.8M Offset / 2x GEOSATpro SL2 LNBFs - Wall Mounted above entrance on the front of the warehouse fixed on KU G19 / SES1
GEOSATpro 90cm / GEOSATpro SL2 / GEOSATpro HH90 motor (58w - 180w+) On Ground Pole Mount near front entrance for testing and demo
GEOSATpro 90cm with GEOSATpro SL2 fixed / Ground NPM near front entrance for testing and demo
That's a sweet dish farm, Brian! I envy the square footage of roof space ;) ...
Thanks! Room for literally thousands of dishes with LOS to either horizon.
The 45' climb up the caged ladder in the riser room, roping materials 50' up the side of the building and more than a few round trips to get a needed tool... takes a little of the joy out of the wide open space! ;)
The lift trucks only reach 3/4 of the way, so many, many blocks were hand over hand roped up. My muscles ache just remembering. Everything is aligned, but will be upgrading the terrestrial antennas in the next few weeks.
Maybe good time to install a hoist on the roof ? :D
Hmm, I think that for me, figuring out which neighbor got my dish in their pasture during the wind storm would be my worst problem. It was bad enough having to go over to the neighbors to get what parts I could of the roof back, about 4 or 5 years ago. The concrete blocks? I wonder how far they would fly. .... Sorry. I have gotten almost no sleep since Thursday morning and my thought have gotten even more weird than usual! If my neighbors got my dishes, they would not let me have them back. They want to take them of my hands for covers for the gardens - to keep the deer off the plants.
And the worst wind of the year, historically in the night of Oct 31st....
In the foreground is a KU dish for PBS feeds, not shown because of tree is a "C" band 6' solid dish. The 8.5' screen dish is "C" "KU" movable. I have 5 receivers on all the time. two 4DTV and 3 DVB receivers.
I so need to clean this up its pretty bad.
Here's a 10' mesh with a seavey circular C band feed that is looking at NSS-806 at the moment. It does very well in nulling out the opposite polarity being an orthomode type feed. The Channel Master dish in the background is an 8 footer also with an ortho on it.
(Shot with a SONY DSC-H2 camera $10 garage sale special!)
Here is my current setup, Channel Master 1.2M with actuator covering about 53 Degrees East to 20 West, the dish is exactly calculated in current position to pass the signal onto the entire surface.
I've also modified the Inverto Black Ultra LNB to flange so i can use the Channel Master feedhorn as you can see below, the systems performs extremely well.
20101207115_1_.jpg20101117095.jpg20120511_192041 (1).jpg20120511_192243.jpg20120511_192115.jpg
Nice installation!! Where you find the "arms" attached From the pole antenna to the wall?
<img src="http://www.satelliteguys.us/attachment.php?attachmentid=82345"/><img src="http://www.satelliteguys.us/attachment.php?attachmentid=82346"/><img src="http://www.satelliteguys.us/attachment.php?attachmentid=82347"/><img src="http://www.satelliteguys.us/attachment.php?attachmentid=82348"/><img src="http://www.satelliteguys.us/attachment.php?attachmentid=82349"/>
It appears from your photos that the clearance to front and back of the dish is a matter of inches? Did you calculate that ahead of time? Or wing it? And, are you getting a reduced Quality due to receiving through the glass window?
Yes we are talking less than a inch here :-) i can't install a longer LNB than what i have, this is the only LNB type i can use if i want to move the dish, thank god Inverto make short neck LNBs.
Yes i did alot of calculation with sinus and cossinus, what you do is that you calculate how far up the dish angle will hit the balcony wall on the satellite with highest elevation, then you calculate how far up the dish angle goes for the lowest satellite on the horizon i can receive, between that you make halfpoint and take into consideration of how far back you need to have the dish edge to clear the opening window of the balcony, i have about 5cm clearance in the opening window.
Example:
Say the height of the balcony wall is 100cm and the height to the roof is 250cm so you have a opening window of 150cm where the signal can pass thru, then your lowest elevation satellite needs to clear the lower wall at 100cm, then you calculate how far back the lower edge of the dish needs to be from the front wall and also how high up from the ground the lower edge needs to be to clear the 100cm for that satellite.
Then you do nearly same for the highest elevation satellite but opposite , in this example the total height is 250cm to the roof and the lowest front wall is 100cm high, you have a opening clear window of 150cm to play with where the signal comes thru, let's check how high the highest satellite will go, this time you need to check how high the upper edge of the dish will go as you already have cleared the lower edge at 100cm, in my example the upper edge will reach 143cm or about that which means there is no problems, the upper edge will clear the signal thru the window.
On top of these calcs you get the distance you need to put the dish from the front wall.
Hope it helped other people doing the same thing...
What actuator is that?
The actuator with the golden arm is from Danish LINAK, they don't make this model anymore, it's from the 80's and in mint condition.
The other one is from Swedish Landis&Gyr, it's not produced anymore, also from the 80's.
It's from the Swedish company Pexymek
http://pexymek.com/index.php/catalog/product/view/id/62/s/vf-2550x2-fasadfaste/category/26/
They make professional mounts for the industry in galvanised Swedish steel.
???? ?????? ?????????? ???? ???????? ??????? ???????? ????????.????? ???????? ? ???? ?? ??????? ??????? ????????? 3-3,5 ?????,????? ???????? ?????????? ??? ?? ???????? 28,2?.
? ??? ? ?????? ? ???????? ????????? ???????? ?? ????? ???????-?????--0,6-1,0 ????.?????? ??????? ????????? ?????? ?? ??????.? ?? ???? ??????? ????? ????????? ?? 3-8 ?????????.?????? ??? ?????? ??? ??????? ?? ???????.
??? ????? ??????? ????????? ? ????????? ???? ?? ????????? ???????? ? ?? ?????????? ???? ? ???????.??????? ???????? ? ?????????? -Mabo-
1.2 ???.jpg1.2?-?????.jpgPA183073.JPGIMG_2998.JPGIMG_3065.JPGIMG_3127.JPGIMG_3139.JPGDSC00388.JPGDSC00390.JPG
My antennas-offset-
Good morning American satellite TV enthusiasts.
Happy new year to all of you, good luck, good health.
I am more interested in your beautiful large-diameter antennas. began collecting on a kitchen garden an antenna with a diameter of 3-3, 5 meters to catch British beam from the satellite 28, 2e.
We in Europe are mainly companions for small antennas-offset- -0.6 -1.0 meter. many satellite are close in orbit and one antenna can take from 3-8 satellite LNB Size affects when mounting the antenna.
Here's what position the satellites I have installed itself on a city apartment and the village of dachas. Antenna Polish and Ukrainian-Mabo-
Thank you for your attention. so far.
Welcome to the forum Boris. You have a very nice setup. Very good work :)
Here's my latest addition. Haven't locked any signals with it yet, but give it time :D
New projects for the new year
How do I install a 40mm LNBF on a Prodelin 8 foot offset dish?
