Need info on this dish. | SatelliteGuys.US
danristheman
3,147
1,145
85w
I have picked up a old Muzak dish for free off the factory right next door to where I live. Does anyone have info on these dishes? I even got the mounting bracket where you put sandbags or cement blocks on free with it. So is this a good deal? I will post pics soon. I swear i am getting addicted to this hobby but its a good addiction.
Dan Rose
How could a FREE dish NOT be a good deal? :D
Is that the 1 meter style ChannelMaster/Andrews/Primestar style dish? If so, it's a great dish for use as FTA KU.
That's what I remember on the last one I saw.
But under the shroud, I think it had a single polarity LNB.
So, for general use, I'd just bolt on a DishNet FSS bandstacked, or voltage controlled LNB .
Sounds like it's the same or similar to mine. Mine was used for Muzak as well. You see the pics of it here. It's 1.2m. I put a C Band LNB on mine. Look at my signature.
I had one of those...nice find.
I talk to the owner on friday of that factory they were going to throw it out he said yea you can have it for free. I got it right in time before they were taking it down from the roof. they asked me if I was going to recycle it i said yes for FTA use not for the trash. there is a lot of cband dishes around in this town that people are not using its a gold mine for cband lovers.
Dan Rose
Have some pics for you guy I measured the dish its around 1 meter.
Dan Rose
it had a spacer on the inside of the lnb took that out and put on a DN superdish Lnb on it. It bolted right up.
Dan Rose
ok it was in the lnb it was a square plastic piece between the cone and the lnb.
Dan Rose
The square piece is a waveguide for single polarity. It allows a C-120-flanged feedhorn to bolt up to a WR-75-flanged single polarity LNB. A C-120-flanged LNB like the DN FSS Superdish LNB is a perfect replacement.
While the feedhorn is conical, thus made for an offset dish, its most likely a Ku-Band feedhorn, not a conical C-Band one.
I cleaned up the arms today used a polisher and some rustolem black paint on the support arms for the lnb. posting pics soon.
Dan rose
Where the pic?
Sent from my DROID using SatelliteGuys
Can anyone get C-band on a 1 meter dish? What sizes did these dishes come in? I look for who made it but no tags.
Dan Rose
Let's see a picture of the back of the dish.
I think it's Channel Master, which was bought by Andrew.
(they made most/all the Primestar dishes, back in the day)
I don't know who Muzak bought from, but they were good commercial dishes.
Might be a Prodelin (bought by General Dynamics); the picture will tell.
Or, someone may recognize the arms or feedhorn.
Common sizes: 0.9m, 1.0m, 1.2m,
& Prodelin sold a lot of 1.8m (6') molded, as well as a few 8' molded offset dishes.
I measured its 1.0 meter does that fall under the otard rules? I'll post more pics. I look at the back of the dish there was no markings on it to tell me who made it.
Dan Rose
FTA Help please
New KU Dish from Gas Station
