Not here. Channel changes are still taking 3-4 seconds for audio/video to appear.Same here.
So, am I just imagining it, or is my guide now staying on my custom list after the nightly update?
After receiving 234, I have not had my external hard drive drop off - maybe that is fixed. Also, I don't know if this showed up in 230 or 234 (I don't remember seeing it mentioned here), but there is now an external drive menu option, and it appears to let you transfer the entire contents of your external drive to your hopper or vice versa. The external drive menu button is also in the Joey menu, but it says it is a future feature.
One thing 234 seems to have fixed...being able to add both sat and OTA of a local station to faves list. Before it would only add the sat channel.
Not the problem...for ONE local station, could not put both in faves list, in my case, Fox affiliate. It would take the sat, NOT the OTA. Others have reported similar.I've had OTA channels in my favorites list since 230.
I've also noticed that the brief loss of audio after pausing and replaying the live feed appears to be fixed.
I've isolated my CC problem with S234 to the fact that it only works on 1 of the 2 tuners that are in use (the second is the PIP tuner even though PIP isn't in use). If I enable CC and it doesn't work using the swap or input keys will switch tuners and it will work on that tuner. If I have both tuners set to the same channel CC will work on 1 of them but not the other.
Watched tonight's update knock off the EHD again. No joy in that department. Also undid one channel's Sat/ota Faves fix. (see above a few posts).
Limited time offer
