if you want something easy, get a wdtv live box. this is your best bet as it has the slingplayer app, and a lot of other streaming content.
That only works with an actual slingbox, the wdtv doesn't work with the sling adapter.
Went to the local apple reseller and they were out of stock on the hdmi adapter.
I'm waiting for a merger between two cable companies in PR to go through. When that happens hopefully I'll have service with 2mbps upload at home instead of 1mb which is what I currently have.
http://www.speedtest.net/result/2750586927.png
I'm also trying to get a nice ota antenna so I don't have to rely on the sling that much. Problem is that I live very far from the towers :/
I'll report back when I get the adapter.
Occasionally we get things first in the USVI. The above is our new speed. Just cam on line a couple weeks ago on St. Croix and rolled out on St. Thomas this weekend. Don't give up hope.
Wow thats simply awesome! How much do you pay a month?
At my apartment I have liberty cable 5mbs/2mbps up for $42 at home I have Claro 3mbps/1mb up for $44 a month. I'm waiting for liberty cable to complete its merger with OneLink which serves my home hoping to get the same service and price that I get at my apartment.
I pay $99 a month. No data caps. Even using a VPN I can easily stream Amazon, BBC, etc.
Hey guys, I finally decided to cut the cord at my apartment and cancel our dish account there. I tried to live with locals but its almost impossible to pick them up OTA.
Right nowI have a hopper with sling connected to my home dsl (3mbps down 1mbps upload). And the PQ is nice on my ipad, iphone and laptop.
So far this is what I have accomplished.
Setup 1- apple TV 2
-hardwired to my network at the apartment (5mbps down, 2mbps up)
-Airplay works!.... Only when in HQ mode and since my home internet is slow, Its stutters in HQ. SQ is watchable but airplay won't work and i don't understand why(only sound)
At this moment the solution to get this working is to upgrade the internet at home where the dvr is. The problem is that no isp offers more than 1mb upload in that area.
Setup 2- Windows 8 laptop connected via HDMI
-works and looks good when I select "better" in the dish anywhere quality settings.
-is a small hassle to carry the laptop and not being able to work while I watch tv.
-need to use my ipad as a remote in order to control the tv
Is there any other way to get sling content onto a tv? If not I'm thinking of building a cheap HTPC or buying a super cheap desktop and plugging it into the tv with a wireless keyboard and mouse.
If you are already using Airplay with your Apple TV I don't think there is any reason to buy the HDMI adapter. From my experience they are both under the same rules meaning apps that block Airplay also block HDMI. If low quality is blocked on Airplay I would bet it's also blocked on HDMI.
Yes but I airplay is wireless which is subject to interference and other variables. I'm thinking the HDMI adapter can help in a small way.
That's true depending on how far you are sitting from the router etc... Remember that airplay doesn't connect to the WAN though. It operates entirely within your internal network and it is capable of delivering much more bandwidth than the external network signal you already have to use through that very same WiFi connection on your iPad to get the sling signal in the first place. Unless you found a way to plug Ethernet into your iPad you are going to have to use WiFi for sling anyways.
The original problem was not airplay quality. The problem was that the Dish Anywhere app apparently blocks airplay if you aren't getting a "high quality" stream from sling. I don't think that will change because you use an HDMI adapter instead of airplay. Usually the same app rules apply for mirroring whether it is through airplay or HDMI. The problem is the WAN speed not that LAN speed. Normally I am all for wired over wireless. I wired every device to Ethernet in my house except for the ones that only support wireless. In this case, however, I think you would just be spending money on an adapter that won't fix your problem.
Sent from my iPad using Tapatalk HD
Limited time offer
