The switch finally arrived and I installed it. Right away I wanted to check the signal strength and the even transponders but from the time I got down from the roof of our rv to the living room there was a software download to interrupt so I let that be and checked another way. The channels we could not get before were now coming in loud and clear, the icons on the menu that were missing before were now there. The guide was populated way past 4 hours already and the todo list was building. So good so far. By now could check the signal strength and the even transponders on 99 and 101 were showing values, EXCEPT, transponders 4, 12, 20, 28 were all zero. Should I be worried about that.
We left the manual programs there just to make sure the guide filled in programs would still work a few hours later and they did. The guide is still there and all appears to be ok, the only issue is that row of transponders all zero, not spaced unevenly like before when I have look at them.
So, is everything OK?
Your are good to go!
We'll we WERE good to go but the same problem just happened although slightly different.
Background:
- worked for 3 days, today we disconnected from shore power and ran our generator for about 35 minutes then connected back to shore power. This means that the Genie rebooted twice
Symptoms:
- all three transponders on 110 (8, 10, 12) now show zero
- even transponders on 119 and 103 are now zero
- 99 and 101 signal strength is as before with great signals on everything but 4, 12, 20, 28
- guide is populated and the todo list looks good but some channels are not coming in, luckily the low definition versions are coming in for those
So far I have stowed the automatic satellite and raised it again but still the same. I am going to go up on the roof and switch cables to see if that does it but based on what I have learned so far I am betting that the even transponder port for 103, 110, 119 on the SWM8 switch has blown.
Does this mean it is the LNB?
I am going up to the roof and switch cables to make sure but I believe it is the even port and not the cables but want to make sure.
I will keep you posted.
BTW Winegard is sending me a new SWM8 switch since it was a Winegard kit that was used to upgrade our dish to SWM. Don't know how this will affect that.
Thanks again for everybody's help, it is muchly appreciated!!
Call Directv, talk to tech support and say the receiver won't power up and have them send you a replacement
Why? It's almost certainly not a receiver problem.
Im not to familiar with a winegard dish, but in my professional opinion, id have to say it is the Receiver. are all your ird's having the same problem?
It is pixelating more than we would like, and occasionally searching for satellite, would that be a symptom of a bad port on the Winegard?
I doubt it's the receiver, most likely the lnb or a cabling/connector issue somewhere. I'd put a bad switch low on the culprit list.
Just to add another variable, is it possible you are damaging something (the SWM8?) when you run the system on the generator? If there are nasty spikes or noise on the power, this could cause problems.
Running the receiver AND the power inserter from a UPS would probably solve any of those issues
You need to make sure your using a 29 v power supply and not a 21v ,that can cause the issue your having with the swm 8 switch
Will check later, thanks for the tip. Is this randomly killing the 18v ports on the swm8 switch since both times it was a different 18v port?
Could be, but they are easy to test with a VOM.
Yes, a VOM is a volt, ohm meter. You put the two probes to the elements on the plug and look at the meter, pretty simple. There should be a diagram on the block of the PI showing which element is positive and which is negative. If you have a digital meter, it doesn't matter which is which, the display will show a negative or positive output. An analog meter will peg the needle quickly if you have it backwards. Don't leave it connected if that's the case, just switch the leads of the VOM.
Limited time offer
