Direct tv tivo dvrhd34 "To record episode press R on your remote control" annoying pop up ? | SatelliteGuys.US
sportman13
352
4
This morning the record pop up appeared on CH 206 espn! and on other ESPN channels and others to I can not get rid of it do you know where I can get rid of it ?
Why do you keep posting about this? You have been told on this and other forums what this is, and how to get rid of it.
I did set up series. did not change the default options on the DVR popup went away but if you need to have (always) at least 6 series links it is not realestic to do your DVR will keep recording shows and fill up my DVR any other way to make pop up go away
The HR34 has a 1 TB hard drive. It's going to take quite a while to fill with only six series links, especially if you watch and delete shows along the way.
moved your post over here. no reason to bring up an old thread and post the same thing ;)
(referring to sportman....not chip)
It's worth noting that you can set up series links that don't actually do anything like new episodes of Bonanza (which there aren't any of) and your drive will stay clean.
DTV and Sunday Ticket parting ways?
switching from slimline 3 lnb to swm no signal problem
