Kijiji, eBay, and Craigslist dishes for you to take a look at | Page 36 | SatelliteGuys.US
Free
This is being advertised by a new home owner as free for the taking. What is it do you suppose?
Well, here it is a bit more than 2 weeks from my email, and I'm picking it up Friday! :D
Does it look like a 10'er? I've been looking everywhere for pictures to ID it, but the only mesh I can find is a 12' with the dual circumferential bands inside the outer edge.
Google Street View
View attachment 89186 View attachment 89185
She's on the trailer next to the house now :) A friend and I pulled up at 10:30 am this morning and were driving away in less than two hours. I grabbed everything except the buried cable and control wires. The dish came off the mount, then was split in two for loading. The polar mount was frozen solid to the pole and wasn't budging. So, I had a Hi-Lift jack and jacked it right out of the ground! It took some grunting on the jack, but it came up nice, slow and easy. I'm going to run out to take some pics...
Im not about to argue with: FREE! ;)
But I've heard there were clones of Paraclipse dishes.
The ribs on this one don't look like the ones on Stoggies big P!
http://www.satelliteguys.us/threads/142822-Care-and-Feeding-of-a-12-foot-Paraclipse
That doesn't make it less desirable.
Havent heard anyone say bad things about clones, but haven't seen one either.
Or are am I wrong about this dish?
Here it is sitting on the trailer, the trailer is 18'
... and the tale of the tape... 12'-4" :D
The circumferential rings at the outer edge.
The polar mount.
Two panels are damaged/pulling out of the frame. How can or should these be fixed? There seems to be a plastic strip at the outer edge which can be removed. Can this be removed then the mesh piece slide out a few inches, then slid back in engaging the slot in the radial rib?
EDIT TO ADD:
Oh, the LNB(F?) is a Chapparal with the feedhorn integral with the scalar ring; all one piece. I haven't noticed that in all my browsing about here and on the webs.
Ha! It's just a 20-minute drive down the highway. No trailer here at all. I don't even have a hitch on my vehicle. I'm a city boy! I'd have to rent a truck. This would not be a simple operation. It's probably too much for me, but it would be fun to see it.
I kinda like the construction.
One piece? Stamped or spun ... steel or aluminum?
Guessing maybe 8'?
For the price you get a nice mount, and maybe restorable motor, regardless if you like the dish (and pole) or not. ;)
...and I like the dish! :up :)
Notice how the pole is set in concrete? Looks like it would give a heck of a fight if you were trying to extricate it.
ADL Cband PF 3.7 to 4.8GHz single feed +scalar
unimesh 12
