We Need Your Help! | SatelliteGuys.US
We Need Your Help!
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,710
29,464
Newington, CT
SatelliteGuys Staff Member Nelson61 has been working HARD on updating our Uplink Report software and data to help us provide you with the most accurate information possible!
Nelson61 has gone through the FCC Database and noticed lots of mistakes in the FCC Database when it comes to the channels affiliation and has painstakingly gone through the FCC Database and compared the information to other sources to try correcting this data so that it is accurate.
If you could please take a moment to check out our listings for your local television market at http://www.satelliteguys.us/thelist/index.php?page=dishnetworkmarkets&sub=true and look over your channels to make sure everything listed is accurate we would appreciate it!
If you do find anything wrong please let us know!
For example...
You take a look at your local FOX station but notice its listed as ABC.
[TABLE="width: 75%, align: center"]
[TR="class: FTA"]
[TD]7383[/TD]
[TD]WTIC (61)[/TD]
[TD]Hartford, CT - ABC, 61[/TD]
[TD]MPEG2 SD[/TD]
[TD]110°W[/TD]
[TD] 20[/TD]
[TD]QPSK (5/6)[/TD]
[TD][SIZE=-2] Spotbeam 04[/SIZE][/TD]
[TD][SIZE=-2]Hartford, CT[/SIZE][/TD]
[TD] [/TD]
[TD]Available
[/TD]
[/TR]
[/TABLE]
Give us as much information as possible, and let us know the correct network so we can correct TheList.
Thanks for your help and for allowing us to make our data even better for YOU!
(And thanks to Nelson61 for all his hard work!!!)
The DC locals look good to me, except I don't understand the (remap) channel numbers for WNVC and WNVA... I think that is actually a Dish problem and not a problem with TheList! At the transition, both stations went onto virtual channels 30.1-12, with WNVC broadcasting subchannels 1-6 on RF24, and WNVT broadcasting subchannels 7-12 on the real deal RF30. Neither channel has been using RF53 or 56 for a long long time, yet Dish still keeps the old/obsolete channel numbers. :(
And of course I never miss an opportunity to point out that the Harrisburg, PA market is inexplicably and erroneously shown at the top of the Washington D.C. market. (The Harrison, PA market shows only itself. :mad:) I'm looking here: http://www.satelliteguys.us/thelist/index.php?search=dnall&sub=true&market=Washington, DC
Biloxi/Gulfport
[TR="class: FTA"]
[TD]5192[/TD]
[TD]WXXV2 (6)[/TD]
[TD]Gulfport, MS - FOX, 6[/TD]
[TD]MPEG4 HD[/TD]
[TD]61.5°W[/TD]
[TD] 20[/TD]
[TD]8PSK (3/4)[/TD]
[TD][SIZE=-2] Spotbeam 62[/SIZE][/TD]
[TD][SIZE=-2]Biloxi, MS[/SIZE][/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TR="class: FTA"]
[TD]6592[/TD]
[TD]WXXV2 (6)[/TD]
[TD]MPEG2 SD[/TD]
[TD]119°W[/TD]
[TD] 02[/TD]
[TD]QPSK (7/8)[/TD]
[TD][SIZE=-2] Spotbeam A14[/SIZE][/TD]
[TD] [/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
WXXV2 is NBC
[TR="class: FTA"]
[TD]6591[/TD]
[TD]WLOX2 (14)[/TD]
[TD]Biloxi, MS - ABC, 14[/TD]
[TD]MPEG4 SD[/TD]
[TD]61.5°W[/TD]
[TD] 20[/TD]
[TD]8PSK (3/4)[/TD]
[TD] [/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TR="class: FTA"]
[TD]6591
[/TD]
[TD]WLOX2 (14)[/TD]
[TD]MPEG2 SD[/TD]
[TD]119°W[/TD]
[TD] 02[/TD]
[TD]QPSK (7/8)[/TD]
[TD][/TD]
[TD]Available
[/TD]
[/TR]
[/TABLE]
WLOX2 is CBS
[TR="class: FTA"]
[TD]5194[/TD]
[TD]WMAH (16)[/TD]
[TD]Biloxi, MS - PBS, 16[/TD]
[TD]MPEG4 HD[/TD]
[TD]61.5°W[/TD]
[TD] 20[/TD]
[TD]8PSK (3/4)[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TR="class: FTA"]
[TD]6594[/TD]
[TD]WMAH (16)[/TD]
[TD]MPEG2 SD[/TD]
[TD]119°W[/TD]
[TD] 02[/TD]
[TD]QPSK (7/8)[/TD]
[TD] [/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
WMAH PBS virtual channel 19 real channel 16
Sioux Falls, SD
KSFY2 (Channel 36 on Dish) is the CW, not ABC. OTA it is 13.2
KWSD (38) is MeTV, it used to be the CW. OTA it is 38.1
In the Hattiesburg Ms market, WDAM2 (virtual 8) is actually now ABC for the area (at least on most systems around here, I would assume that Dish is the same).
Jackson Tennessee market lists WBBJ3 as ABC. It is actually a subcarrier of WBBJ (the ABC affiliate) and it carries the CBS network programming.
Memphis Tennessee market lists WPTY as being in West Palm Beach, FL. If it is, they must have a mighty tall tower. :D
2 Hopper 2 Joey questions? Reguarding interface.
Missing program icons
