We Need Your Help! | Page 2 | SatelliteGuys.US
We Need Your Help!
Boise, ID
This is our FOX station:
[TABLE="class: grid, width: 500, align: center"]
[TR]
[TD]5253
[/TD]
[TD]KNIN (11)[/TD]
[TD]Caldwell, ID - CW, 11[/TD]
[TD]MPEG4 HD[/TD]
[TD]129°W[/TD]
[TD]04[/TD]
[TD]8PSK (2/3)[/TD]
[TD][SIZE=-2] Spotbeam 11[/SIZE][/TD]
[TD][SIZE=-2]Boise, ID[/SIZE][/TD]
[TD][/TD]
[TD]Available
[/TD]
[/TR]
[/TABLE]
This is an independent station, with no network affiliation:
[TR]
[TD]5255[/TD]
[TD]KTRV (12)[/TD]
[TD]Nampa, ID - FOX, 12[/TD]
[TD]MPEG4 HD[/TD]
[TD]129°W[/TD]
[TD]04[/TD]
[TD]8PSK (2/3)[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TR]
[TD]7138[/TD]
[TD]KNIN (11)[/TD]
[TD]MPEG2 SD[/TD]
[TD]110°W[/TD]
[TD]25[/TD]
[TD]QPSK (5/6)[/TD]
[TD][SIZE=-2]Spotbeam 41[/SIZE][/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
This is an independent station with no network affiliation:
[TR]
[TD]7140[/TD]
[TD]KTRV (12)[/TD]
[TD]MPEG2 SD[/TD]
[TD]110°W[/TD]
[TD]25[/TD]
[TD]QPSK (5/6[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TABLE="width: 75%, align: center"]
[TR="class: FTA"]
[TD]5192[/TD]
[TD]WXXV2 (6)[/TD]
[TD]Gulfport, MS - FOX, 6[/TD]
[TD]MPEG4 HD[/TD]
[TD]61.5°W[/TD]
[TD] 20[/TD]
[TD]8PSK (3/4)[/TD]
[TD][SIZE=-2] Spotbeam 62[/SIZE][/TD]
[TD][SIZE=-2]Biloxi, MS[/SIZE][/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TR="class: FTA"]
[TD]6592[/TD]
[TD]WXXV2 (6)[/TD]
[TD]MPEG2 SD[/TD]
[TD]119°W[/TD]
[TD] 02[/TD]
[TD]QPSK (7/8)[/TD]
[TD][SIZE=-2] Spotbeam A14[/SIZE][/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
WXXV2 is NBC
[TR="class: FTA"]
[TD]6591[/TD]
[TD]WLOX2 (14)[/TD]
[TD]Biloxi, MS - ABC, 14[/TD]
[TD]MPEG4 SD[/TD]
[TD]61.5°W[/TD]
[TD] 20[/TD]
[TD]8PSK (3/4)[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TR="class: FTA"]
[TD]6591[/TD]
[TD]WLOX2 (14)[/TD]
[TD]MPEG2 SD[/TD]
[TD]119°W[/TD]
[TD] 02[/TD]
[TD]QPSK (7/8)[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
WLOX2 is CBS
[TR="class: FTA"]
[TD]5194[/TD]
[TD]WMAH (16)[/TD]
[TD]Biloxi, MS - PBS, 16[/TD]
[TD]MPEG4 HD[/TD]
[TD]61.5°W[/TD]
[TD] 20[/TD]
[TD]8PSK (3/4)[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TR="class: FTA"]
[TD]6594[/TD]
[TD]WMAH (16)[/TD]
[TD]MPEG2 SD[/TD]
[TD]119°W[/TD]
[TD] 02[/TD]
[TD]QPSK (7/8)[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
WMAH PBS virtual channel 19 real channel 16
will do.
The channel numbers are in the data stream and we can't change them
thanks
Jackson Tennessee market lists WBBJ3 as ABC. It is actually a subcarrier of WBBJ (the ABC affiliate) and it carries the CBS network programming.
Memphis Tennessee market lists WPTY as being in West Palm Beach, FL. If it is, they must have a mighty tall tower. :D
will do
thanks
[TR]
[TD]5253[/TD]
[TD]KNIN (11)[/TD]
[TD]MPEG4 HD[/TD]
[TD]129°W[/TD]
[TD]04[/TD]
[TD]8PSK (2/3)[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TR]
[TD]5255[/TD]
[TD]KTRV (12)[/TD]
[TD]MPEG4 HD[/TD]
[TD]129°W[/TD]
[TD]04[/TD]
[TD]8PSK (2/3)[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TR]
[TD]7138[/TD]
[TD]KNIN (11)[/TD]
[TD]MPEG2 SD[/TD]
[TD]110°W[/TD]
[TD]25[/TD]
[TD]QPSK (5/6)[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
[TR]
[TD]7140[/TD]
[TD]KTRV (12)[/TD]
[TD]MPEG2 SD[/TD]
[TD]110°W[/TD]
[TD]25[/TD]
[TD]QPSK (5/6[/TD]
[TD][/TD]
[TD]Available[/TD]
[/TR]
[/TABLE]
will do
thanks
The uplink program defaults to the primary call sign when one of the new digital sub-channels is missing from the station table and will duplicate the primary call sign and affiliation.
There were thousands of edits so I would expect to see more errors.
Station locations are as registered in the FCC database (when found in the FCC station table).
The uplink program does not recognize station affiliation changes so we need to enter them in the station table manually. Your feedback when changes occur will keep "THE LIST" current.
2 Hopper 2 Joey questions? Reguarding interface.
Missing program icons
