Direct tv Gennie 44 Questions | Page 5 | SatelliteGuys.US
I will click on the picture..that blows it up...click on it again and it makes it even bigger for GENIE Recamends
As for the check both 1080i and 1080p, I looked and all resalutions are check is this right ?
No. Only check 1080i and 1080p.
Rey I set it and check 1080i and 1080p. and set it like it said it set it to 1080i and 1080p and 480 is this right ?
NO, read. ONLY means 1080i and 1080p ONLY. Not 480i, 480p, 720p. ONLY 1080i and 1080p.
This will also make SD channels look slightly better. UNCHECK 480i, 480p, 720p. CHECK 1080i and 1080p. Turn native off. Next question...
Done next question
Genie (HR44) for scoreguide it seems you hit the green button not the red to see the scoreguide anyone else ?
There isnt even a green button on the new remote.
The green button is for SAP/Español...
There is also no green button on the HR44 remote, unless you're using the normal remote in the proper mode. Either way:
Red: Scoreguide/Interactive features
Green: SAP audio
Yellow: Info
Blue: Mini-guide.
Yes using the normal remote in the proper mode HR44 remote is it the green button
First we need to ask some questions so that we can help you. What receiver are you using? What remote are you using? And what color is the button you are pushing ?
If I may also ask, what exactly are you trying to access? I may have missed it.
Yes iceberg, but what receiever does he have now.
installation no show?
needing some basic router config advice for GenieGo
