STBs Tell You Nothing While Blind Scanning | Page 2 | SatelliteGuys.US
If your looking to just watch tv and dont care about the complexities behind the scenes then a STB is by far the easiest route. If your like me and find the complexities the interesting part, and want to know every behind the scenes detail then STB's are a waste and PC tuners are king. I'll have to look into adding failed lock tp's into my blindscanning portion of updateDVB, I had never thought of it before this thread but can see that being a valuable resource.
UDL
You sit and watch a screen entice you with signal freq/pol/SR reports but the receiver doesn't tell you what those signals are, or how strong they are, or how close you are to locking them if they are using a format compatible with your receiver.
some of the older DVB receivers when locked on a TP would show the signal quality. I know the Coolsats would show signal quality when locking and if it was a "weird" format (like DCII or DVB-S2) the meter would go up but still be in red (green meant it was locked on a DVB TP)
I've seen my Coolsat 7000 do this. I wish this receiver supported DVB-S2 then I'd still use it.
The AzBox miniMe American Edition does this as well on both blind or transponder scan for DCII or other "weird" formats it can't demodulate.
GOCE Satellite falling to Earth
Satellite meter settings
