Whats the average or max video bitrate that DTV's HD is set at?
Yes DirecTV. I don't need a specific number, just a ball park idea is fine.You are talking about Directv /D* here, right, not DTV (Digital TV) .
Just wanted to clarify.
When I first saw it, I thought DTV, not Directv, even though its in the D* section.
I thought Direct has since moved to 6 per tp on some tp's?
On some, yes.
I would imagine that D* does put 6 channels on some transponers, more than likely they can do that alot with a group of channels that are mainly stationary, such as talking head shows, that type of thing.
Locals on Spot beams, they will cram more on each Transponder. There are some dedicated Transponders, that have two to three channels only on them, per contract with that provider. They do that, so they can roll over channels from a bad transponder, to a good one if needed.I would imagine that D* does put 6 channels on some transponers, more than likely they can do that alot with a group of channels that are mainly stationary, such as talking head shows, that type of thing.
With the Olympics coming up, I am sure that they are going to request as much bandwidth as they can, to be able to give the best PQ, along with probably a 4k feed if we are lucky, since 3D is dying.
Yes, as always. Only thing is, everything major will be tape delayed this year again, just like Beijing & Australia.Thanks ...
NBC again ?
and CBC as well.Thanks ...
NBC again ?
and CBC as well.:
and I goofed. It starts February 6th
Limited time offer
