@ Tou-can... IMO, its just a pain in the rear to set-up a monitor/receiver outside. Much prefer the convenience of a meter.
Cheers, K
Cheers, K
A bit error rate display should pry me out of my stupor and get me headed towards your solution. I'm interested, intrigued. For right now, in the absence of this, and as one example, by pushing the dish left and right to the edge where error correction can no longer cope, is the center point between those two extremes an approximation of where the sweet spot will be seen by your ber set-up ?I tweak on a strong tp to get it close, then purposely pick a really weak tp or one with a hard fec and tweak with ber.
spectrum analyzers are super helpful for this, many USB/PCIe tuners support this now. I use mine using X11 over ssh or NoMachine over ssh so I can run the app on my desktop but see it on my laptop outside.
With receiver and TV: Plug in long power cord. Drag end out to dish farm. Drag out card table to dish site. Set up table. Carry TV to card table. Carry receiver to dish site. Plug in receiver and TV to power cord. Connect LNB to receiver. Connect receiver to TV after you have brought those cords(coax) out to dish site. Turn on receiver and TV. Set both to what you are looking for. Start "wiggling" dish. Found signal. Lock in dish. Now remove everything and drag it all back to the house.Meter still seems redundant if you're able to bring the box and a monitor. What does the meter do that's different ?
With meter: Carry short coax and meter out to dish site. Connect meter to dish. Turn on meter. "wiggle" dish for signal. Found! Lock dish and remove coax. Walk back to house with meter and short coax.
That is what a meter does that is different.(or a heck of a lot less work)
RT
Agree 100%. Too dang cold in Wisconsin and Michigan for dish work in Winter. The DO hold up very well.......I don't tweak dishes in the freezing cold and rarely at all because these systems are extremely reliable.
I acknowledged the convenience factor many posts ago. I don't tweak dishes in the freezing cold and rarely at all because these systems are extremely reliable.
You will be quite disappointed with the spectrum analyzers in these inexpensive units. The scan / refresh time is extremely slow and there is no calibration or accurate scale. They show signal presence, but not very useful for optimizing the installation.
Personally, I use the Applied Instrument as well. Would recommend a used AP meter over any of these inexpensive alternatives! There is no comparison in quality and results.
Straight from the horses' mouths...I know a few people who have Superbuddy's and only use in their home and love them. I guess it all depends on how serious you are about the hobby....
...Truth be told I have had other sponsors send me their meters to review in the past and I opted not to post a review for them just because the quality and functionality was so bad. I figured it was better to say nothing at all in those cases.
But the Superbuddy line and now with the AI Turbo S2 I can proudly stand behind and say it is truly SatelliteGuys approved.
I get the convenience issue. A meter is less work. As for doing a better job, I'm not so convinced. We're talking about pointing a dish, not landing on the Moon. There is elegance in doing more (or at least the same) with less. Usually this is a difference between hobbyists and professionals: hobbyists have the luxury of time and the final result is not necessarily inferior. I'm sure I will appreciate a meter when/if I get one. I wonder if these 6 pages of posts answered Kraven's question?Straight from the horses' mouths...
I have been thinking about a meter but have not yet bought one for similar reasons. It seems like many of the cheaper meters are essentially satellite tuners without the video image. If they are just giving me S and Q readings, I have receivers that can do the same. I also have the mild California weather on my side too.
I checked out the AI meter and it does look very nice, but at $850 it also costs more than my entire set-up. I totally understand why some people would have such a device, even hobbyists, but it's more than I am willing to spend on a meter. I'll have to keep an eye on Ebay or CL for used models.
Limited time offer
