Super Joey does not connect to the node, it connects to the LNB on the dish, through the integrator. The integrator connects like a Joey would to the node.Super Joey's only work on a solo node and require an integrator.![]()
An extra Hopper may add 3 tuners to the setup but it's not fully integrated like adding a Super Joey is.
Where did you get this information? Doesn't seem logical to me.Super Joey's only work on a solo node and require an integrator.![]()
I have an installation diagram showing the use of a DPP44 switch and the SuperJoey is connected through an integrator to one of the DPP44 outputs.Super Joey does not connect to the node, it connects to the LNB on the dish, through the integrator. The integrator connects like a Joey would to the node.
How do you know that only solo nodes will work? Seems like one half of a duo node would function the same as a solo node and the other half of the duo node could be used to connect a second Hopper.Yes, but they only work in conjunction with a solo node (i.e. No duo nodes). Sorry for not being clearer in my earlier post.
That amounts to the same thing as a line directly from the LNBF.I have an installation diagram showing the use of a DPP44 switch and the SuperJoey is connected through an integrator to one of the DPP44 outputs.
This is getting old, the SJ for now is for those with 1 hopper - not 2. Enough already.
What is the point of having more than one Hopper with a Super Joey other than to say or prove to the "nay sayers" that you can? What are you going to use the extra three tuners for when you can't integrate them into the five tuner Hopper/Super Joey set-up? That seems to me to be like having two ViP 722k's that can't see each other.
I agree especially with the OTA dongle. Has it been stated that the Super Joey cannot accept the dongle? Say that you want the Hopper in a central location of the house to make it easier for the wireless Joey to access it,versus Hopper on one end of the house & wireless Joey on the other end. Does the Super Joey have a USB port that you could hook the OTA device if that is the only way you can get OTA?The ideal config would be two Hoppers w/two Super Joeys. Even better would be if the SJ could handle the OTA dongle.![]()
That is a shame as far as the Super Joey goes.The Super Joey is the same as a regular Joey but it has 2 tuners. The regular Joey is not able to use the OTA dongle and either is the Super Joey.
Limited time offer
