If I upgrade my 622 to a Hopper system do I need to have all the wiring replaced or upgraded? Or can they just install the Hopper using my current wiring and dish?
Is the orange burial cable RG6 3ghz? That's the only cable the Dish installer laid out that I didn't provide. Everything else in my home is RG6 3ghz.
If you live in a cold climate, make sure they put the node indoors. At one point there were problems if the node was outside in cold weather.
Do not forget the addition of the node. The tv2 lines will need to be rewired since they will now go to the client of the node. Other then that the wiring is similar and may be used. Also make sure it is rg6 cabling. Rg59 will cause major moca errors.
Please provide the link where Dish says we can no longer use RG-59 to the Joey.Do not forget the addition of the node. The tv2 lines will need to be rewired since they will now go to the client of the node. Other then that the wiring is similar and may be used. Also make sure it is rg6 cabling. Rg59 will cause major moca errors.
It isn't the RG59 that is the problem. DISH MoCA runs under 1GHz and that's well within the range of any RG59 cable that isn't absolutely rotten or otherwise severely damaged.I'm glad it is working for you, however it is still an unsupported connection that has proven to cause moca issues.
Considering I'm doing this on my phone I'm not about to go link surfing, however you can go to mydish.com and check out their wiring diagrams. And as far as what works and what is supported. Those are two seperate things. Dish only supports the rg6 cabling, so their technicians will replace any non rg6 cabling as a precaution. Unless they are lazy. And if audited will fail a quality inspection.
i believe that was in combination with a particular LNB and the older version of the duo node.If you live in a cold climate, make sure they put the node indoors. At one point there were problems if the node was outside in cold weather.
Limited time offer
