Tevii tuner cards | SatelliteGuys.US
Tevii tuner cards
Decoding 422 video is dependent on the codecs you have installed on your computer not the card itself.
I use a HDstar usb tuner that has the same Montage demodulator and tuner as the dvb-s2 tevii cards and I like it. I slave it off my openbox s9 primarily to watch 422 video and also to get detailed feed information.
My main receiver is a TeVii S464 DVBS2 PCI card. Like 77TA said, it's not the card that does 4.2.2, it's the software in the computer. :)
Does the S464 work good with the asc1 or should I loop through my hdvr1200 the card is going in a 10 year old computer unless I go with the s662 USB for my laptop
What is the best DVB-S2 PCI/PCIe card for use with LINUX?
Al Jazeera Is Now Scrambled
