ForumRunner should work.Looks good! I noticed the change since I usually log in with Forum Runner on my phone and it told me you down down -- but then came here and noticed the software changed; it still reports your down though. Hopefully XenForo supports the Forum Runner plug-in -- I don't want this to be the only forum I can't follow on my phone easily!![]()
In your Profile-- PreferencesI like the new look. Is there any way to show more threads on a page, or do I have to hit the next page button a lot?
It worked for me. I changed mine to 25.First thing I did. Still only shows 10 threads.
The only constant is change. I would rather be inconvenienced than be threatened by security holes being exploited. Godspeed....
I changed mine to 50. It worked here.First thing I did. Still only shows 10 threads.
Now how the heck was I able to change my preferences ? Now I can´t find that menu.
Click on your acct name upper right-hand of the screen. It's in the pull-down menu.
Got it thanks, it´s taking me a little time to get used to this new look.
Limited time offer
