Hopper w/Sling Hard Drive Failure WTF | Page 2 | SatelliteGuys.US
I know it really sucks but I think that's just the nature of hard drives. Any receiver with a build in hard drive can have the same thing happen. I had it happen to me with my old 622 receiver years ago. Same thing can to computers, that's why they say it's important to back up files.
Dish does not make the hard drives. And the hard drive is a mechanical device. Like any other mechanical device it can die at any time. Unfortunately nothing DISH can do about it. The drives are rated for a long long life, but still some do fail early in their life. :(
That's just fine if we're talking about catastrophic physical failures. But what about times when the receiver says the drive has failed, but it works after a reboot? What about times when it says it's failed, the reboot doesn't fix it, but it works fine after a reformat? I've seen both of these, and so have other people. I assert that both of these conditions have to be at least partly software issues, not hardware.
The advice for backing up your data is a good one, EXCEPT, Dish does not allow for backing up, only transferring to an EHD, which is not a backup. If the EHD fails, you still lose your recordings. Now I suppose you could transfer to an EHD and then do an image copy of that EHD to another drive, but that can be a pain to manage.
I suppose if some show are that important they can always be burned onto a DVD. I know I like to keep my recordings but when I do lose them I get over it fast. Chances are I'll see it on TV again to record or I can find it online.
It would be nice if Dish had a back feature. I do image my drive - it is a hassle. I also own my Hopper. I have been in the computer business for over 2 decades. Heat is the enemy. I have an Antec laptop cooler under my Hopper and the cover off. Average temp of the hard drive is 86 degrees. Highest temp is 97 degrees. I watch the temps on all my PC hard drives. My Hopper is just over 2 years old - April, 2012. The hard drive in my Hopper is from Seagate. Not my favorite hard drive company, but so far it has been trouble free.
That does work fine
I use acronis image copy option to back up my hard drive before I moved from my h2k to my hws and restored from the copy on the hws. That way if I hit one of the external hard drive bugs I still had my original hard drive
Reactions: dare2be
Yep, HEAT, or more heat from being in an enclosed cabinet or other furniture for TV/audio equip can greatly accelerate the death of an HDD. The solution I and many others on this forum have found if we have to have an STB in an enclosure is to use a laptop fan and place the STB upon it. It is quite effective with greatly reduced temperature noticed from the display of the "Tests" list. Yes good air flow no matter where you place your STB.
Also, the same problem if the STB is placed on top of or even under another device that creates it own high heat. I ALWAYS place Dish DVR's upon clear plastic casters (or sometimes krazy clue 2 or 3 casters for added height if atop another heat producing device) to allow for airflow UNDERNEATH the box, as well. I've observed that airflow UNDER the Dish STB seems to be very important.
Now, it isn't so critical to use casters with TiVo because the fans on TiVo are always running and running pretty fast such that you can't help but hear them working. So, TiVo units--except the new base Romio unit) is doing a much better job of cooling because the fan is really doing the work it should. However, while the Plus and Pro models of Roamio continue to cool this way, the base Roamio does not cool as efficiently do to it's internal design. I've had people complain that the nightly reboot of the ViP Dish DVR in their bedroom would wake them up at night. NOT ME.
The reason Dish does not have the fan activate except in conditions when the STB is getting too hot is that Dish has gotten LOTS of complaints over the many years from customers who say the sound of the fan is bothersome, especially in bedrooms, but people complain even if the STB is in the living room. Does anyone remember the BIG complaints about the 721 fan being on all the time and it bothering people. The fan really needed to be on, but eventually Dish fixed it so the fan was OFF except for extreme conditions. Dish probably fixed it so the 721 wasn't doing too many things at the same time as a way of reducing the heat and, thereby, being able to shut the fan off.
The sound of a fan working at moderate levels just does NOT bother me. Of course, when the fan is really working at high level, it sure can be annoying, but, again, at moderate or normal level it does not bother me in the least even though I can hear it, but there sure are a lot of people who can't tolerate the fan at a normal level. I suppose we are all different.
Dish no longer on list of providers for history channel app
Dish Anywhere Browser Plugin
