Photo. Satellite Dish Europe-Russia. | Page 5 | SatelliteGuys.US
Yea it goes to more LNBs, nice set up.
I disagree. Why would it need to go to more lnb? The black tubing is called flexible waveguide btw. Its a lot less lossy than rg-6. Chances are more like they go the receiver(s) Its an ortho setup so one each for H & V. The LNB's look like external reference units.
Reactions: Titanium
Motor repair by the hands. Motor Strong SRT DM-2100
For 8 years of work of my motor, has appeared small gap./slack/. Dish, has disassembled the motor and has found malfunction. The plastic washer became less in thickness-0,35 mm. I found thicker - 0,55 mm. Has established a new washer and play was gone. The excellent signal became on all satellites.
Arrow-has removed this washer
Red arrow-new thicker a washer
Some motors have an adjustable wedge to take up slack in the worm gear axle. I prefer the washer. Less chance for it to go out of adjustment.
Thank you for the great pictures!
Reactions: Borisov-54
Apart from all these workers have made another important component is the Ground:
Good afternoon.
In a dispute, truth is born.
So we argued at our European forum. Who first started drilling holes in C LNB, so that no condensation would remain. In which year in America did they start drilling at the bottom of the hole in C LNB ...?
My first unfortunate experience was in the C range service, at the beginning I did not drill a hole. And that's what happened- / 1 photo /.
The signal after a couple of years fell from the satellite. I disassembled the LNB and there the dirt inside. I cleaned, drilled even 3 holes by 2 mm and everything was fine with the signal and there was no condensation inside.
Reactions: RimaNTSS
Channel Master Editor
103 ,99.2 105 w
