I am ordering a VOD that on the on-screen-guide says is 1080p online. On the online order page it says the video format is HD in a grey box. Should it say 1080p for the video format?
So you can't use a ppv certificate for a 1080p movie?I believe you can only order 1080p VOD on the device itself not online.
I thought it just reverts to "regular" HD, after testing, if your TV doesn't support 1080p. I tried it years ago, with a TV that only did 1080i (and was connected with either component or HDMI-to-DVI) and I vaguely recall that it told me my TV didn't support the resolution and that it would display it in a compatible format.My thinking is that they have to know that your TV is set up properly to accept 1080P
The PPV is $5.99. Are you sure you got that on 501??? Or 504??I just checked one, Dracula Untold. The 1080p version is $6.99 while the regular HD version is $5.99.
I believe this is the case. In my case I was trying to order "Lucy" and I got the order ID from VOD channel one and it said it was 1080p. I think it said it was $6.99.I believe you can only order 1080p VOD on the device itself not online.
Limited time offer
