Yesterday I had a Hopper with a super Joey installed by a Dish Contractor (replacing my DirecTV). As you can see from the pictures, not a very pretty installation (btw, one story house).
The installer reused the original DirecTV coax cable from their dish to a grounding block (it is the coax that is partially painted). He reused also the DirecTV foot mount and the mast. To be fair, I did ask him to see if he can use the DirecTV eave mount because it is much better than any of the mounts that Dish is using in our area. However, I didn't expect him to reuse the mounting foot and the mast especially since the DirecTV mast is larger in diameter than the DISH. What he ended up doing is spreading the Dish mast clamp to fit over the DirecTV mast and using much longer screws to clamp it together. Everything else under the eave looks like it was thrown together by a kid. BTW, he didn't run new coax cables to the house, the original cables were perfect and it still took him 3 hours to do the install. Am I too critical of this installer?
OK, now for my real problem. The Hopper is wired directly to my Router and I have no problems accessing the Internet on that TV. However on the Joey's TV, I have no access to the internet. I thought that all Joeys have access to the Internet once the Hopper is connected to the Internet, or did this guy screwed it up completely.
