If I'm wrong I'll accept it, but all the evidence Leeds to the fact that you shouldn't terminate a power passing port.
I don't think you are supposed to terminate switch outputs, Like DPP44, I believe they are supposed to be capped.You should always terminate all unused ports.
If your using a duo hub for a hopper3 install. That was the original question asked on here. I was tell the person they would be smart to use a solo hub due to the unused power passing portOk I've slept a few times since, you may have got 1 up on me. What scenario would you have an un-used pwr port open in a working system?
This is for the old Solo, Duo hopper setup requirments.In my experience yes. There is definitely voltage present on an unused host port when another rcvr is connected and plugged in on the other port. Be it ports on a dish, switch, node, hub. And the terminator definitely creates a short in the system. If you wanna test that, terminate all un used ports on a switch and see what happens in the next 24-48hrs. It will get the switch,rcvr,or the lnbf. Whichever is the weakest
YesOk what about the un-used open ports on the lnb with 1 receiver. Voltage present?
But the Nodes I think can be terminated because it's powered by the receivers ,Not an external PI.
Directv Swm 16 also calls for No terminators on the swm 16 it's self, But the unused Ports on the Splitters and even the IRD on the PI must be terminated.
I'm fairly confident as long as it's not a Multiswitch output port, You are supposed to terminate all other open ports.
I will order the solo hub!I feel my credibility slowly coming back. No offense, we can all learn from each other. No matter how long someone has been doing this. Love to all
Host ports are not Powered until you plug Hopper into it.I promise you, that is referring to unused client ports only, because there should never be a situation where you have an unused host port.
Limited time offer
