Well that stinks. I just ordered a 650 last week. It should be here tomorrow. Does it work with the Hopper? My old Harmony remote worked with the H3 without having to change anything from my 722k.Now that I have the H3 my wireless Joey has Carbon UI and I can't get a code to work on my harmony remote 650. Any one have any luck?
Have not tried with the H3. Maybe I will tonightWell that stinks. I just ordered a 650 last week. It should be here tomorrow. Does it work with the Hopper? My old Harmony remote worked with the H3 without having to change anything from my 722k.
My 650 works fine with my Hopper 3. I do not have a Wireless Joey to test it on. As mentioned by another user, I will have to add the "Power Toggle" feature to get the receiver to turn off (standby). I noticed last night that it did not turn off the receiver when I powered everything off. I will have to add that tonight.I've tried Hopper 3 as my device also for the Harmony 650. Still can't get it to work. Setting it up as wired or wireless Joey doesn't work either. Usually these Harmony remotes work well with dish items. I'm stumped on this one.
Did you check the settings like I mentioned in my previous post?I've tried Hopper 3 as my device also for the Harmony 650. Still can't get it to work. Setting it up as wired or wireless Joey doesn't work either. Usually these Harmony remotes work well with dish items. I'm stumped on this one.
Carlos please remind me about the settings you talked about - thanksDid you check the settings like I mentioned in my previous post?
I realized in my Joey settings of the new carbon UI that by default infrared remote was disabled. In your dish settings if you go to settings/remote and at the very bottom see if thats the case with you as well. If it is, then enable that setting and see if that works. I couldn't get my harmony working by setting it as a wireless Joey, but it does work for me setting it as a joeyCarlos please remind me about the settings you talked about - thanks
The Elite touch screen works more crisply than on any of my previous Harmony remotes. It's everything that the new Hopper remote should be, even includes the color buttons (color button prompts are still on screen with the Carbon interface.)
And...... Problem solved! Sorry I missed this if you posted before! Love this forum. Thanks CarlosI realized in my Joey settings of the new carbon UI that by default infrared remote was disabled. In your dish settings if you go to settings/remote and at the very bottom see if thats the case with you as well. If it is, then enable that setting and see if that works. I couldn't get my harmony working by setting it as a wireless Joey, but it does work for me setting it as a joey
Can confirm the Harmony 650 remote works with the Wireless Hopper Cabon UI! thanksWell that stinks. I just ordered a 650 last week. It should be here tomorrow. Does it work with the Hopper? My old Harmony remote worked with the H3 without having to change anything from my 722k.
Good to hear the comments on the Elite. I'm still using my old trusty 880, but looked at the Elite a few times. First new Harmony in a while that's caught my attention.
Limited time offer
