Yes they were for the intended use of connecting to the internet. They still work on the Joey 2.Since the wireless adapters on the original Joeys were never really supported by Dish, I wouldn't hold my breath on that one getting fixed. The fact it doesn't work at all now may have actually been the fix in Dish's mind.
I thought the USB adapter was specifically for headphones? That's why they (the Dish tech) sold it to me and it works perfectly on my WJ's. It adds a "bluetooth" option to "settings". My IHip Bluetooth headphones (also purchased from Dish tech) paired the first time and every time since. I love being able to use my phones in other rooms rather than just near my H3.Yes they were for the intended use of connecting to the internet. They still work on the Joey 2.
You're confusing adapters. DISH has both a WiFi adapter and a bluetooth adapter. The 4K Joey has bluetooth built in but not WiFi so an adapter is needed.I thought the USB adapter was specifically for headphones? That's why they (the Dish tech) sold it to me and it works perfectly on my WJ's. It adds a "bluetooth" option to "settings". My IHip Bluetooth headphones (also purchased from Dish tech) paired the first time and every time since. I love being able to use my phones in other rooms rather than just near my H3.
sorry - my brain read "adapter" somehow (I think that word was used in post #2) - not unusual for meYou're confusing adapters. DISH has both a WiFi adapter and a bluetooth adapter. The 4K Joey has bluetooth built in but not WiFi so an adapter is needed.
Why does the 4K Joey need a wi-fi adapter? Doesn't it get it's wi-fi from the Hopper?You're confusing adapters. DISH has both a WiFi adapter and a bluetooth adapter. The 4K Joey has bluetooth built in but not WiFi so an adapter is needed.
I believe that would be the "Wireless Joey". Pretty sure they are two separate animals.Why does the 4K Joey need a wi-fi adapter? Doesn't it get it's wi-fi from the Hopper?
I believe that would be the "Wireless Joey". Pretty sure they are two separate animals.![]()
I know they definitely are - sorry - I didn't mean to confuse anything or anyone.I believe that would be the "Wireless Joey". Pretty sure they are two separate animals.![]()
Could be no cable run to the room, or no cable run to a specific side of the room they want it placed.The title of this post is "Wireless USB doesn't work on 4K Joey"
What I meant was - why would the 4k joey need a wireless adapter? Doesn't it network via MOCA with the Hopper?
Like I said in the earlier post, my guess is that is why they apparently didn't add support for the Wireless Adapter in the 4K Joey. I doubt that it's just a bug.
From what someone at Dish told me, up to the Joey 2's, video streams was able to be handled over wifi, but THEY said (I don't doubt it but I am dubious about the reasoning) they said 4k streams would've been too much bandwidth to be reliably handled over most wifi...and they disabled the ability...plus Sports Bar mode is (will be) handled in the Joey's themselves (as Swap currently is now) and the "Sports Bar" mode's 2-4 streams are too much for consistently reasonable wifi connections.
Everything in your post here has ABSOLUTELY nothing to do with getting a wireless internet connection to a 4K Joey.From what someone at Dish told me, up to the Joey 2's, video streams was able to be handled over wifi, but THEY said (I don't doubt it but I am dubious about the reasoning) they said 4k streams would've been too much bandwidth to be reliably handled over most wifi...and they disabled the ability...plus Sports Bar mode is (will be) handled in the Joey's themselves (as Swap currently is now) and the "Sports Bar" mode's 2-4 streams are too much for consistently reasonable wifi connections.
The Joey gets all its video over the MOCA connection.
READ the F**ing post the WiFi is need for the INTERNET connection. UNDERSTAND?Uhh...what? If you are trying to connect a 4K Joey wirelessly (which isn't possible), how do you theoretically think its going to get that MOCA connection? And if you are connected via COAX to get the MOCA signal, why are you concerned with the Wireless adapter?
Limited time offer
