Is there a cover on the feed horn?If not wasps think that is a swell place to build a nest and keep the probe from turning.
Ok, I will try to reverse the motor wires next... and are you sure the sensor wires are correct/colored too?EDIT: reverse the motor wires and try again
If still error:
Now you're going to need a battery to see if the actuator works.
But first, take the back cover off and inspect it for water infiltration.
And check the wires for continuity.
OK; the receiver needs a "mind" reset; as the battery when it goes un-used for a year or more will make the mind fuzzy; and E14 can be this. But I see another problem; you have no cable going between the analog 4000 and the motor controller box; a heavy smaller box with a plug connector that goes between the receiver and the power supply box. The 4000 did hook polarity powers directly from it to a stationary dish. E14 means also the cable is not hooked between the two (2) box set. It basically looks the same as a GI 2000? two (2) box set using the same "an old houston tracker cable will work" 8-pin type plug cable?4 pins were ???) and a GI power supply...and the motor wires and pol. wires? then go to this box instead...but the plug connector hooks between the two boxes to control both or one of these satellite selections of forward/reverse pol. and east west controls.
Also, the 4000 models in the newer era of its lifetime did have powers for the motor builtin and FATAIR is correct...
but yes, i do have a GI power supply availlable; for controlled C Band motors...and it works with a gi or a echo 4000 (and my old PC)...
And it should still get an analog channel; like F3 CSPAN>... The motor wires hooked up to the unit before? The dish has a motor already; and it worked; then where the two big wires (larger motor wires) should be able to move the dish. The way it works to check their voltages is to hook a volt meter to the two east west motor lugs on the receiver; and go east or west with the remote; the e14 will show; and the meter will show a brief 24-36 vdc +- on the meter. If you continually put a pulse train (touching a wire between the two pulse or sensor connections) then the 24-36 vdc will stay on while you make up a continual count to it (motor supply). Normally, Also, if at anyrime the two sensor wires have been plugged into a wrong lug or even touched to a wrong log while unit is plugged into electric 120vac; (12 vdc is the 3rd lug and big trouble) then the sensor on your motor outside will blow (they are normally 5vdc reed sw). Otherwise, E14 means no pulse is being received by the receiver and the wire going to the dish must be checked for continuity; or if they are shorted by mouse; vermine; man; no pulse can mean the cable between the dish and receiver is shorted or open...if the motor is bad or the cables to it are shorted or open; e14My SRD-4000 unit is self-contained... my setup is just the dish itself , the wires to the receiver, and the receiver itself... there has never been any external power supply or motor unit to this receiver, when it worked 8 years ago, before I disconnected the wires and cables and stored the receiver away.
opening the motor up to expose the connections will tell. (but I'm 99.9% sure I'm correct) If I'm wrong oh well.Ok, I will try to reverse the motor wires next... and are you sure the sensor wires are correct/colored too?
As a side note: You can remove the DCII module. (plastic affair right below the motor screw terminals. Just wiggle it out) Battery is probably dead. and there's only one channel up there, but getting a subscription to it is a no go. So now it's just another unnecessary load on the receiver's power supply.
Yes, the cable/wires and the receiver are all original. This setup worked 8 years ago before I disconnected the receiver and wires from it. I didn't touch any wires to the dish itself.And it should still get an analog channel; like F3 CSPAN>... The motor wires hooked up to the unit before? The dish has a motor already; and it worked; then where the two big wires (larger motor wires) should be able to move the dish. The way it works to check their voltages is to hook a volt meter to the two east west motor lugs on the receiver; and go east or west with the remote; the e14 will show; and the meter will show a brief 24-36 vdc +- on the meter. If you continually put a pulse train (touching a wire between the two pulse or sensor connections) then the 24-36 vdc will stay on while you make up a continual count to it (motor supply). Normally, Also, if at anyrime the two sensor wires have been plugged into a wrong lug or even touched to a wrong log while unit is plugged into electric 120vac; (12 vdc is the 3rd lug and big trouble) then the sensor on your motor outside will blow (they are normally 5vdc reed sw). Otherwise, E14 means no pulse is being received by the receiver and the wire going to the dish must be checked for continuity; or if they are shorted by mouse; vermine; man; no pulse can mean the cable between the dish and receiver is shorted or open...if the motor is bad or the cables to it are shorted or open; e14
SRD = single (satellite? or one (1)) receiver (digital audio) - I mostly worked on a 5 foot dish with a pr1e aimed at G1 (for galaxy one had all the dish needed; no motor needed). But then; the SRD4000 changed into motored dish type (like a houston tracker); and had a power supply box seperate. Then it got built into the SRD4000; and the motor lugs worked (but were not hooked up in the older SRD4000).
This was also about the time Echostar sent modulus to Mexico; and a deal was made (the plane crashed and mystery is what or why it did, pilot was doa and the 1000 modulus burnt up).
You could mark the feed throat/scalar relationship, then rotate the throat 90° to get on Horizontal for now. IK-PIB.
Check continuity of the motor and sensor wires. 8yrs, water could have corroded them to mere oxide.
Once you get the actuator working,you should be able to move the dish to a position where you can reach the feed horn.yes, there is a cover on the feedhorn... I will try to take a picture of the feedhorn and actuator when I get a chance... The actuator I can get too via ladder. but the feedhorn is in the middle of the dish mesh and not sure how to access it w/o stepping into the mesh dish itself...
Also, I am stuck on 121W and I don't see any analog channels. But if I hook upmy MPEG2 receiver, I get this BON and RT Esp as listed in Lyngsat.:
3780 V
tp 4
C
41-43Level 3 DVB-S 29270-7/8
781-4096
7.2
P Parente
160106
Blue Ocean Network
112 3120 3121 E
3122 E
RT Español
113 3130 3131 Sp
3132 Sp AC3
So I know I am stuck on V polarity for now.
I do have voltmeter to measure any leads/connectis you want (see my prior screenshots).
Limited time offer
