RV Setup | Page 2 | SatelliteGuys.US
RV Setup
Just wanted to add that those instructions are for a 1000.2 Western Arc dish and LNB. If you're using a 1000.2 Eastern Arc dish and LNB you only need the first 2 wires from the left.
I'm trying the pics again to make sure we are in the same page.
Also, I wasn't aware that I couldn't pass the power inserter for the DPP44 through the Node. I will try it's own line to port 1 and the node out of port 2 and 3 of the switch.
I'd get a 1000.2.
OK. I'll look into that. Camping this weekend so I will try the setup from above with the dedicated line for the power inserter to port one and the Node in ports 2 and 3. After seeing my pictures, will I still need all 4 cables from LNB's hooked to the switch? Like I said before, I really only need sat 110 for this weekend.
Request for OTA EPG Help in South Bend, IN DMA
Hopper 3 "lost" Tuesday Oct 25
