OK, thanks, was wondering why they are so expensive on eBayNope, don't think they have in a number of years.
As Greg says, no more DP lnb, on eBay right now between $30-$45 apiece, as soon as they are listed in bulk you have to be lucky to catch themDon't they make dp dual output lnb?
were you an installer?I need to check this out...wondering what to do with all my old dish equipment.
you can pm me if you find any dp or dppYes, Retailer and installer for many years.
I only need dp and DPP lnb's, thanksI have one.
Its used obviously, and it does work.
I'm just in an area where the 129 is weak, so I have no use for it with my 500Plus dish.
If you want to supply the box and obviously shipping costs.
Or even just the Shipping costs, I may have a small box I could send it to you for free.
PM me if you are interested.
I can send it out Tuesday.
Okay no problem.I only need dp and DPP lnb's, thanks
Never mind.QUOTE="Troch77, post: 4007407, member: 195955"]Okay no problem.
Even though thats what this is.
Lol
.The other dual sat lnb is what?
I also have a Brand New in box DPP33.This is a single DP LNB with single port. The DP single with dual ports will let you take the same sat signal to two receivers.
No its not.This would be a DPP twin.
http://www.ebay.com/itm/Dish-Networ...-sat-option-/181142535951?hash=item2a2cefbf0f
Read aboveI think the DPP LNB twin he has for the eastern arc.
http://www.ebay.com/itm/Dish-Networ...-Plus-EA-Arc-72-61-5-Satellite-/182210093790?
hash=item2a6c9162de
Limited time offer
