I've had a HR44, H44 and HR54 Genie's and never had a problem with 'soft' PQ and this was on a 73" DLP and 65" 4K UHD set.
I have an HR44 with a three year old Vizio, it has a good picture.
Did some research last night and found someone on the other satellite forum mentioned they think their Genie doesn't provide as good PQ. Come to think about it my sister has a Genie at her house (HR44), and it to me looks a little on the soft side (more cable-like as well). My parents have old HD receivers, and their PQ looks fantastic.
Could it be that these new Genies are delivering "softer pictures?" I know some of you say the PQ is good, but have you also tried an older HD, non-genie receiver on the same TV to compare?
Could it just be a HDMI handshake issue? I am not sure how that works, so please excuse my ignorance.
My HR54 looks fine on my 70" Sony UHD set. I had a Tivo Roamio OTA before that. Looks pretty good to me.
Did either of you happen to see the PQ with a non-genie though first? Thanks for the replies!
Not on the 65" 4K but the 73" had a H21, HR23 and HR44 on it at various times and didn't see soft PQ,
I had an HR24 on the same TV. I don't see any difference.Did either of you happen to see the PQ with a non-genie though first? Thanks for the replies!
I don't have any slow downs when downloading or at any other timeThanks for the replies, everyone! I guess I'll just have to accept it. It's not bad...just not spectacular like I had thought it.
I notice that through the app there seem to be more episodes of shows available -- why is that?
Also, does downloading of shows through On Demand slow down the Genie?
What seems to make the Genie slow down at times? I have seen this from time to time (unsure of the cause) and want to avoid it if I can.
Thanks again
Thanks again
Stephen, since you are a new member we'll forgive you but your post is full of misinformation, mainly installer "urban legend".There's a few places settings need to be changed to get beat PQ. First go to menu, settings, video, resolutions, and make sure all boxes your TV supports are checked. Genie boxes automatically pick the best resolution possible as lone as all are checked. Next, while on normal picture (is live tv) hit the info button to bring up the top bar. Using the arrows go to audio/video. You should see the broadcast resolution as 1080i-original format. If it's not set to that click it until it changes to 1080 original. It's a vital step that techs sometimes forget to get best PQ.
Nown if a box is taking a long time to respond, there's a few things that could cause it. First thing I would check is the wall plate where the coax line plugs into the wall. Unscrew it and look to see what color the inside is. It should be orange. If it's clear, white, or blue it should have been changed out at install.
If the wall barrel is orange at the client and the genie, i would check to make sure that your boxes aren't set for native format. Menu, settings, display, preferences, should be the top box if I remember right. Turn native off.
Then don't forget to hit INFO then scroll right to the AUDIO/VIDEO option then CHANGE RESOLTUION & FORMAT and make sure that it's got 1080i native selected.Thank you, guys, very much for the information! Learning more every day.
I don't know if my TV or DTV box has better upscaling. I think I'll try to do Native Off and 1080i like you suggested (well Native Off is already set but then I also have 720p, 1080i, 1080p all checked). My Samsung has a great picture but is about 6 years old.
If you have 1080p checked as a supported resolution the box will automatically switch to 1080p.
Limited time offer
