Where, in your house or the RV?Ok I just tried installing the receiver and I'm getting a message can't detect swm. Please help!
In the rv. Do I need a SLM?Where, in your house or the RV?
What model number receiver did you get?In the rv. Do I need a SLM?
I meant swm. Sorry this is all so confusing. I connected the cable and all and it's telling me it's unable to communicate with the dish.In the rv. Do I need a SLM?
And at least Dish will allow a Wally on the same account with a H3 I understand, so you can use that in an RV or for tailgating.
Sl5s4nr2-01The 24 series doesn't need to be on a swm setup. What's the model number of the lnb?
Also is a power inserted needed?Sl5s4nr2-01
This lnb sat for a while and wasn't used. Could it be bad?
Yep ...Also is a power inserted needed?
If a power inserted is indeed required which one is recommended?Yep ...
It's a SWiM LNB ....
Sent from my LGMS550 using Tapatalk
For a SWiM LNB either a 21v (black colored) or 29v (Gray colored) PI will work.If a power inserted is indeed required which one is recommended?
Thank you. And what cables go where ?For a SWiM LNB either a 21v (black colored) or 29v (Gray colored) PI will work.
There are a number of helpful sites ...Thank you. And what cables go where ?
Thank you.Go from the lnb to the power inserter to the receiver.
This lnb sat outside in the yard for a few years without being used. Do you think I should replace it with a new one? If so which one would you recommend?Thank you.
First, do you need 119W?This lnb sat outside in the yard for a few years without being used. Do you think I should replace it with a new one? If so which one would you recommend?
Limited time offer
