I cannot get anything on 95w. This signal keeps popping in/out. Anyone else having issues or am i having a problem?
Thank you.
Thank you.
Just checked - getting CGTN News & CGTN Documentary on ku just fine with Q between 70-75.I cannot get anything on 95w. This signal keeps popping in/out. Anyone else having issues or am i having a problem?
Thank you.
I only have the overly-optimistic meter on the Linkbox 9000i to go by, but no issues here on my 90cm motorized. Pegged at 98% signal level and signal quality.
You're welcome! Good luck, hoping for an easy fix. Let us know what happened.I was afraid of that... Ugh, okay, i gotta figure out where the problem is. Thank you.
That definitely is weird! I'm getting solid 85Q today (better than yesterday) so not the satellite. Does it happen at the same time of day? Maybe terrestrial interference or sun reflecting into lnbf?I recently adjusted a new dish for 95w. Is it possible that i am on some sort of ghost signal that works part of the day? It's doing it again, the signal is dancing on/off. Weird.
If you'd lock the barn door,the signal wouldn't get loose,just don't lose the key.i would LOOSE the signal. Between 11am and 3pm...
If you'd lock the barn door,the signal wouldn't get loose,just don't lose the key.![]()
Limited time offer
