New Genie UI now in CE testing | Page 8 | SatelliteGuys.US
OK, hey everything appears to have kicked in several hours ago on my HR54 ...
Mobile DVR, VOD, channel logos, My Teams, Genie Opt-in, etc.
All working fine right now, ...
If I could just increase the font size ...
Reactions: Jimbo
Just had to wait for the clearmybox 2 do to its magic. Patience grasshopper.
I find the new Recording List more confusing and it's not clear what you have already watched or not, it also doesn't tell you when episodes were recorded unless I'm missing something, I dislike the fact that there's no longer a mini guide for the channel you are watching to see upcoming programming without having to open the full guide.
Let alone the small fonts and blurry icons, I understand this is why it's called beta software though, but I do hope those things get fixed before national release.
If you go into the Recording and hit INFO, it tells you at the bottom when it was recorded,, but it's not on the main screen anywhere.
Don't know for sure since I did it and then left the house for awhile, it was there when I got back a few hours later.
Oh, thats not too bad, I was thinking a day or two.
If I can get my On Demand back, I'll continue to do the CE's, but I stopped for awhile because the stuff I may be needing wasn't showing up after a weeks time.
I don't always use the Extras options, but when I need them, I want it to be there.
I downloaded the latest update for me which showed up but it was 0D80 not 0FCC but I haven't been on CE for a long time, is that the only place I can get the 0FCC download for my HR44/500 ? Thank you.
PS Does anyone have a link to the CE or EC forum which ever its called I forget.
If you leave your box off.. and have no recordings or tuners active.. a Clearmybox should restore everything within 2 hours(box will reboot on its own after an hour) if it doesnt then something is messed up
iamanedgecutter
Remember the CE download times usually begin every Friday and Saturday evening at about 11:00 PM to around 2:30 AM the following mornings EST.
What you just d/l'ed, 0x0D80, is the new NR in the process of rolling out typically around 3:00 AM to 6:00 AM EST Monday through Sunday.
Reactions: paranoia
Remember the CE download times usually begin every Friday and Saturday evening at about 8:00 PM to around 2:30 AM the following mornings EST.
You mean 11 pm, Est, not 8 ... :)
Unless things have changed and I missed I t.
best lnb to upgrade to SWM
STARZ ENCORE ESPAÑOL
