FOUND A NEW TOOL, love it, and its free | SatelliteGuys.US
No it's OK my IT buddy put me onto it, he hates bad evil crap that is out there, this one is OK I have a fast desk top he custom built for me
google the sh*t out of it, you would find and negative stuff on it
Gary, you still didn't give any explanation beyond "Try it, you'll like it". Remember that commercial. The next line was "So I tried it. Thought I was going to die"
What is the purpose of the link? Why will it make my whites whiter?
I've been using Glary Utilities for YEARS. The Pro version is only $11 a year. It is worth it to have all the little maintenance utilities ( which you can find and download for free ) in one easy-to-use interface. It is updated quite frequently and different/new tools are added on occasion. I don't use everything in the suite... mainly the registry stuff, disk space optimization, and the defragger. It will track the programs you have installed and query you when there are updates for them. I mainly use this for information and manually update instead of letting it update for me. I think the repository they use is File Puma.
I've been paying for a Pro license for a while. I think the free version has no limits but buying the Pro version gets rid of the nag screen when starting it up. Not a huge annoyance and I felt the $11 was acceptable to support the project.
Reactions: KE4EST
A few years ago many subscription companies added PC cleaners to their collection. I have mine through the virus scanner collection. What I like is it keeps the registry file clean and fast. Prior to these tools, I used to go in and manually clean the file with regedit. Glad those days are gone.
Reactions: navychop
I've been using the Pro version for about a year. It is quite nice. Much better, to me, than System Mechanic, which I used for a long time.
Been using CCleaner for years. Don't need anything else.
CCleaner only cleans out temp files and cookies. Glary is a complete suite that does everything including looking for software updates, driver updates, check disk, defrag, PLUS cleans out temp files, redundant shortcuts, analyses start up programs, running tasks, defrags, cleans and defrags registry, removes spyware, etc... All the things to keep a happy computer running smoothly and up to date, so yeah, you actually DO need something else.
I also use advanced system care, the tool box alone is great, try it, then buy it There support is good too, they even give you a way to do a screen shot for an issue to send them, so their software guys can figure out the special problem you are having, they seem to be willing to bend backwards until your happy. They email you, ask you if the special one they send you fixed your issue
Top Anti-Virus - Advanced SystemCare Ultimate 11 / 10 / 9 / 8 / 7 Download - IObit
Reactions: HipKat
Upgrade Windows 10 System Disk on an HP Computer
