4K Events Discussion Thread | Page 11 | SatelliteGuys.US
Do the Hopper3 & 4K Joeys record actual 4K or 1080i/P?
The Hopper 3 will record in 4K, I still have some 4K recordings from the Rio Olympics. 4K Joeys get their information from the Hopper, they don't record anything. You will be able to watch those recordings from the Hopper on the 4K Joey though.
Thanks for the update, so on my H3 guide, no 540, I see 146 - select for info; just a slate for other channels.
147 says 2018 winter - 1 channel. description says select this channel to expand/colapse the olympics channels, nothing happens when I select other than the + at the left turns to a -
according to the slate 208 cnbc, I only show a 207 - olympics info slate
I don't have 389, just 402 - wintr
159 - winter app, says app in red, nothing happens on select.
105 - USA; just shows regular shows...
so maybe I'll need to chat with dish; maybe still to early
Again I have flex + whatever freeform pak & locals added on at this time. during CFB I had the sports pak, and got all the 4k games on 540 that were offered.
You're in much the same situation as me. CNBC is in the News Pack which you don't have; NBC Sports and 4k channels require AT120 or above; Olympic channel requires AT200. DISH needs to clarify in their advertising what the requirements are to get each channel when there's a chance some confused customers won't get it. I was hoping they might put some of it in "free preview" mode or maybe offer an additional package that included it.
I concur that the "channel" for the app does nothing, you have to go to the apps menu and launch it from there.
Reactions: pattykay
What model 4K HDR TV do you have?
I remember a previous Olympics (summer Olympics) when it required AT250 to get all of the channels. Dish had a special deal for the Olympics where you could upgrade from AT200 to AT250 for a month at no additional cost, or at a reduced cost if you were upgrading from AT120 or AT120+ to AT250. If AT200 is all that is required this time around, then maybe Dish should offer the same kind of deal, where AT120 or AT120+ subscribers could switch to AT200 for a month at no additional cost, and offer a reduced-cost upgrade for Flex Pack subscribers.
I found this interesting from the above link: "Tune to Channel 100 to watch NBC, NBCSN, CNBC, and USA channels all at once with the NBC Olympics TV Experience."
Is Dish really going to put the local NBC on the national multi-view channel 100?
idk, samsung 65" something from black friday 2016. same model Sams carries.
Maybe there is a setting that isn't quite right. I know in my LG OLED there is one setting that if not set correctly, I don't think the 4K and HDR will get thru from Hopper/Joey to TV. But I am not 100% sure of that, I am still learning this TV. I read a post about the setting in the AVS forum. This morning I tuned in to channel 147.05, the HDR indicator came on in the right hand corner and the picture was awesome. There was no program on at that time but the Hopper guide and settings menu was stunning.
On my H3 I had added to my Favorites147-1-2-3-4-5 yesterday (Wednesday Feb-7) checked the guide it was there...Checked today 147-1-2-3-4-5 disappeared...Had to go back and re-add em???
My J4Ks don't have 147-5?
I don't think its a TV setting; I was able to watch 4K football on 540 when it was airing.
Reactions: charlesrshell
I now have 147-05 and 540. The both say 4K HDR. Both say my TV is not compatible. So us early buyers of 4K are left out of NBC's decision to go with HDR. I received all previous Dish 4K programs on 540. The Dish site still says only 4K on 540. I hope that becomes true so that all 4K TVs will be able to see the NBC 4K programming.
Ok, I'm more confused after a chat.
It seems at200 is needed for Olympics, but 4K answer confuses me more.
Don't think I'm going to pay $25 to watch the Olympics. not a sports fan here.
Timkenn_OPID_WAW (15:41:49 GMT) : Olympic Channel (OLYMP) HD channel is available at Top 200 programmin
bryan (15:42:25 GMT) : what about 4k?
Timkenn_OPID_WAW (15:42:53 GMT) : 4k resolution will be effective right away on the account since you have the Hopper 3 equipment.
bryan (15:43:43 GMT) : So at200 will have 4k coverage? what channel #? 540?
Timkenn_OPID_WAW (15:44:02 GMT) : That is correct.
Timkenn_OPID_WAW (15:44:31 GMT) : It will actually depending on the channel owner itself if they will air the programming at 4k resolution, Bryan
Timkenn_OPID_WAW (15:45:00 GMT) : As long as your equipment is in 4k capable receiver, any channel that will be aired in 4k will work on your end
bryan (15:45:32 GMT) : huh? Aren't you (Dish) My channel owner?
Timkenn_OPID_WAW (15:46:20 GMT) : We are only the service provider, Bryan. Channel owner of its every channel are different from Dish itself.
bryan (15:47:45 GMT) : So with my current programming, flex + locals, will I be able to watch any Olympics? other than my local NBC coverage?
bryan (15:48:06 GMT) : I don't think my local broadcsts in 4K, only on Dish 540
Timkenn_OPID_WAW (15:48:26 GMT) : Olympic channel is not part of the Flex pack plan, Bryan. In order for you to get it added on your programming, you will need to make an upgrade from Flex pack to Top 200
Timkenn_OPID_WAW (15:48:43 GMT) : Yes, Bryan. 4k viewing option will be only available at channel 540
bryan (15:48:56 GMT) : ok, thanks
In my guide it says Off Air 4K HDR for both channels 147-05 & 540.
hopper plus PIP question and a couple others..
DISH gives DIRECTV the Bird...
