Genie Recommends | SatelliteGuys.US
Genie Recommends
Blackloz
869
83
Minot,ND
I've Had my HR44 since 2014 and back then the Genie Recommends wasn't bad it even picked up the odd show I liked. Lately it's all garbage. All it's been recommending is pay per view. I never have and never will purchase a pay per view. Why is that all it's "Recommending" now? I'm probably going to go into the menu and find how to turn it off.
Go to Menu-Settings-Genie Opt In
From there you can turn the Suggestions On or Off.
Reactions: whitewolf8214
Like the op I've never used it and since the new gui has been released I've option in and so far it has been missing .
So that makes me think it's no longer part of the cross platform gui .
Even though it still shows on the menu.
I'm running 0x1037 so far with no change to gr functionality it's no longer active
I must be missing something as I scoured the guide and didn't see the option in settings or search.
Of course you need have a Hr44 or HR54 or HS-17 to see it
Using the NEW GUI & Remote - it's menu -setting - (RIGHT ARROW OVER) to box GENIE Opt-in - (PRESS) Select - make a choice and then wait - so far I've been waiting for 8 weeks with no GR anything
MLB Spring Training Games
4K equipment upgrade
