OTA bought from and installed by dish picking up all the local channels except for the ABC network. If I unhook the OTA from the dish receiver and hook it directly into the tv, then I can get all the local channels including the ABC network.
When I tried OTA, I found that the tuner in my TV was much better than the OTA module (that I used with my HWS). I could get a lot more channels with the tuner in my TV vs the Dish tuner.OTA bought from and installed by dish picking up all the local channels except for the ABC network. If I unhook the OTA from the dish receiver and hook it directly into the tv, then I can get all the local channels including the ABC network.
We aren't paying for the local channels through dish. That's why we bought and had dish install the OTA antenna. The scan doesn't let you add channels manually, but that is good idea. Another person in this forum posted that their tv pulled in more channels than their dish receiver so maybe it is just the receiver. Maybe the next newest receiver will be more powerful and pull in all the channels. At least we have all the local channels but ABC. Thanks for your response.WJET Channel 24 should be easy to get, as your test did hooking directly to the TV. Have you rescanned the DISH locals? If yours allows you to add them one at a time, do that and go to channel 24 that is where WJET both actual and virtual is. If not just do a total rescan.
Do you know if there is there any way I could change to a better adapter? This looks like the one we haveThe dual adapter for OTA has a weak tuner. It's not surprising that your TV's tuner is better.
This is on amazon, is it the same one, I can't tell.You might be able to find one of the old single tuners on Ebay. I don't see any of them on there right now, though.
NO it is not the Dongle for the HOPPER. You might try buying another one and see if it works better then return the bad one.This is on amazon, is it the same one, I can't tell.View attachment 131642
....The scan doesn't let you add channels manually, but that is good idea. Another person in this forum posted that their tv pulled in more channels than their dish receiver so maybe it is just the receiver. Maybe the next newest receiver will be more powerful and pull in all the channels.....
If DISH would adjust there meter sensitivity to 40, every subscriber can lock even low powered locals
We really need to see a Tvfool report for your location to give accurate advice. WJET coverage goes away quick to the east. It looks like it could be extremely difficult to receive starting as close as 15 miles from the tower in the Findley Lake / French Creek area.
What model antenna was installed?
I have no idea why Dish can't/won't provide an OTA dongle with the necessary sensitivity.
Limited time offer
