Almost bought RG6. What's the 3 gig wire called?3 gig tested. Older wirer [RG-6} will work fine also. But the installers are trained to say you need 3 gig tested cable
Also important on a cable system but not satellite unless you live next to a broadcast tower.Dual or quad makes a difference on the crimp connectors.
I'm not sure if you mean a cable system for satellite TV or Cable TV.Also important on a cable system but not satellite unless you live next to a broadcast tower.
Not according to Dish Network. They SAY it fails at 3Ghz... I say it fails at the point where it says DirecTV on the jacket........ I use it all the time, no problemsSolid signal . xxx perfect vision quad shield solid copper. Good stuff.
What do you mean "HD coax"?The HD coax was higher quality than the stuff I got at an electrical supply house.
Limited time offer
