Obviously not. Number of cables is related to number of receivers in use (and of which family), not reception. I only have one cable for my H3. Another Hopper would require a second line (as well as the old Super Joey). .I know that I am on the western arch (110 119 129) and have 1000.2 dish and a hybrid 3 LNBF but I only have two coax cables running from the dish to my house.
Should I have three coax cables running from the dish to the house?
InterestingRemember the Hybrid technology changed the two channel multiplexing on a coax cable of Dish Pro Plus (DPP) to 16 channels on a single coax. Actually I think it is really 32 channels, just no need for it yet.
So a DPH 1000.2 only needs one coax from the LNBF multiplexer to the Hopper 3 or the Solo Hub if distributing the signal to brings all the satellite channels to the receiver.
Can you tell what the two cables attach too in your house?Interesting
So I have to wonder why I have two coax cables running from my dish to my house?
Not sure but I can tell you that the two cables go to a grounding block on the outside of my house and continue from the block into the house.Can you tell what the two cables attach too in your house?
If you had a previous install that was a VIP, earlier Hopper, etc, it took 2 cables from the Dish. If you got upgraded to the Hopper 3 or a Hybrid System, only one cable is used and the tech left the other one there, not connected to the LNBInteresting
That is it ! I just upgraded to a H3 from a VIP.If you had a previous install that was a VIP, earlier Hopper, etc, it took 2 cables from the Dish. If you got upgraded to the Hopper 3 or a Hybrid System, only one cable is used and the tech left the other one there, not connected to the LNB
Limited time offer
