Adding 2nd 211K to 1000.4 dish | SatelliteGuys.US
ggw2000
693
110
Out here somewhere
I currently have a 1000.4 dish with a 211K hooked to the 61.5 port (I think). I want to add a 2nd 211k and run a cable to the LNB (hooked to adjacent 72.7 port).
Will this work and if so will I get all the programming that i have on the original 211K?
Thanks, Gerry
Thanks, Gerry
Pretty sure all outputs on that LNB feed both 61.5 and 72 combined, so yes, you could use any open port on the LNB (others please correct me if I'm mistaken)
Did the Wally have 2 tuners from the get go and the second wasn't enabled until recently? I am really curious how the dual tuner works with that unit
Not only that, there were rumors c. Wally introduction that had the possibility of putting 16 Wally's on a single cable to a hybrid LNB or hybrid switch. To my knowledge, that was never implemented.
It works for Commercial accounts by using Channel Stack splitters, but it is limited to 8 Wally receivers per Hybrid output, since each Wally now uses two tuners.
Will this setup work?
BBC World News
