ses2 87 w | SatelliteGuys.US
ses2 87 w
kdjuan
153
23
on the satellite mainly and some other satellites
not all the fta channels are coming in.
what do i need to do?
I don't have any problem with the Luken MUX at all. Last evening I checked the signal level on SES-2 and it was 95/90. It would be helpful to know what you're not getting verses what you are getting. I have had times when the signal level would drop to zero and a second later come back on while you were watching something.
like on 97w iam able to get justice tv, buzzr, atv and others. but not able to get laff, bounce, grit or escape
so all are on a different transponder now.
Look to see if the transponder VoomVoom listed is in your transponder list. If not, add it using that information, save it and then do a blind scan on that one transponder. No need to do a full scan. They should scan in and work fine. :)
Titanium C2W-PLL Troubles
Digital Breakup on 101 C Band
