2 Hooper3's install | SatelliteGuys.US
2 Hooper3's install
zplugger
85
27
Fenton MI.
Looking for a good pic of two hoopers 3 with eastern Arc hybrid LNB, on a two hooper 3 system do they have to talk to each orther ? Like to keep them separate from each other,upstairs and downstairs.
It won't work with one hybrid LNB. You would either need a DPP LNB and a DPH42 switch, or two separate dishes with hybrid LNBs. Each Hopper 3 can have its own Solo Hub (if you want to add Joeys, if there are no Joeys then the Solo Hub would not be needed).
Reactions: JSheridan
So two hopper 3's will work of one hybrid dish if you use a DPH42 switch ? Trying to align a eastern dish 61.5, 72 with the dishbox signal finder. It is so slow to respond on moving the dish, is their a cheap meter a DIY user can buy and make it easy ? Just cant get them both working, skew is set and elevation to spec, this is no fun with winter coming.
Not a hybrid dish, a DPP LNBF with a 42 Switch. The switch converts to Hybrid
Sioux City NBC/KTIV STILL blacked out.
Changing Satellites
