Can't really blame them for compressing the crap out of C-SPAN. Is that even available in HD?
Yes, all three C-SPAN channels have been available in HD since 2010.
Why is this fail? Have you seen the service yet?Those are really low bitrates. They have basically carved up a 55mb stream into a bunch of SD channels. In 2019, that's a big FAIL in my opinion
Most SD channels on satellites like 97w Ku and 117w C use 5x the bandwidth and look like absolute crap. I was amazed how good the SD channels looked and now even more impressed after seeing the bandwidth used.
At the shop I swap between a 55" 4k and a 34" 1080p.What size TV set are you watching on out of curiosity?
Sent from my iPad using the SatelliteGuys app!
And I believe that may be higher bitrate then what DISH is serving their HD at (in MPEG4, I dont believe they are using HEVC yet)I agree. Looks great for so little bandwidth. I'm impressed. Looks like the "HD" is maxing out around 4Mbps at peak but in a range from 1.3 to 4Mbps.
Remember this is MPEG4 HEVC which means you can put a lot of data into very little bandwidth.
Everyone who has it seems surprised how good the picture quality is.
The new compression is amazing.
Amazing how much HEVC signals can be compressed and still look better than the same channels viewed on my Suddenlink cable service!
"HD" Channels this is what CS said:
TNT
TBS
AMC
A&E
Comedy Central
Lifetime
Own
We tv
Discovery
History
ID
HGTV
Food Network
Animal Planet
TLC
Nick[/QUOTE
It is all relative. As Brian noted, if you're used to 97W or DIRECTV SD, Orby SD probably looks quite good.Correct me if I'm wrong, but wasn't it stated here previously that all of Orby's channels are SD?
Correct me if I'm wrong, but wasn't it stated here previously that all of Orby's channels are SD? If that is true, then why is everyone so excited about it? I am not interested in SD channels. I can't imagine the majority of consumers in today's marketplace are interested in SD channels.
These viewers need a service that can deliver LIL and Orby can't do that.There's also plenty of people around the country that can NOT get OTA tv through an antenna, even if put outside.
Limited time offer
